Chimney cleaning Kit.. You must have if you are old than 50...👍👍
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
The reason I bought it was because I was afraid to climb the roof due to my age.
Now, I don't have to climb to the roof to clean the chimney pipe nor remove the sanction of pipes.
It is so convenient and so safe.
Jkk
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #2
Nice video, the only problem with it is, where would one buy such a kit? No links to what the thing is even called. Oh well.
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #4
OK, with a few search terms, I mustered up the product.
Drill Powered Chimney Cleaning Kit Flue Brush Cleaner Fireplace Sweep Rotary​
Product Identifiers​
  • Brand
    VEVOR
  • MPN
    3FGDG001
  • GTIN
    0800000575023
  • UPC
    0800000575023
I'll need the 12 meter length kit. So if any rod does break, I got SPARES. :)
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #6
Are you just eating ash and stuff the whole time you use it?
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #7
oh, I think this video is even better. No mess sprayed all over the house! These people have done the job a few times from the looks of things. I got a stove pipe going up 2 stories in a vaulted ceiling. It's a breath taking view, yet a real PITA to keep cleaning. LOL
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #8
i have to go up on roof every year to clean pine needles, clean gutter anyways. so i clean the flue at same time.
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #9
ugh, I use to do the pine needle cleaning too. Then got a better pipe vent cap to keep those out. And the leaf blower or power washer keeps the pine needles off the roof now. I don't have to walk the roof anymore.
When we got the place within the 30-days of closing, a 120ft pine fell on the backside of the house and roof. What a pain and mess to clean up. Glad the old maple had a strong limb nearby to take the brunt of it, else the back half of the house would of been a total loss.
Since then, DW had all of the trees close to the home fully removed.
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #10
Getting pine needles out of roof gullies and other traps is definitely a chore, but an important one. FWIW: I have moved to cleaning the gutters from the ground with an extended nozzle for my leaf blower. They are brand specific, but there are universal ones, too.
(No, that's not me...)
I also use the long nozzle from the ground to blow leaves off the roof.
All the best,
Peter
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #11
All the best,
Peter
I have the deck on one end of the house. So up only 1/2-way on the 6ft ladder. Then with the power washer, blast 80ft for straight gutters each side. It gets squeaky clean. If it's really dry, the leaf blower, nut it takes longer. LOL
Now, the down gutters, leaf blast them upwards from the base.
So, back OT, I'm really attracted to this cleaning method. 50% of our hoe heating is with wood. We knock off all bark and are really selective with the quality of wood burned to keep the creole levels to a minimum. For a Chimney Sweep guy to come out, it's $250 a pop !
This is not a savings heating with wood then. DIY safety to clean makes the savings even better!
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #12
vevor doesn't "Make" anything.
Think Sears, Walmart, etc
They have the items made to sell.
Here is link you could buy it or research for better price on E bay, Amazon.
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #14
We have a 12/12 pitch roof. No getting up there so I brush from the bottom up. First time everyone else was ready for a sooted mess inside, but not the case at all. Wait for a cool day outside, so fine dust travels "up" and out with no downdraft. Also use the leaf blower for gutters, just stay upwind of the plume.
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #15
It won't work with my stove, as it has some type of blanket on top of the combustion chamber
I also go up from the bottom. After disconnecting the stove and taking the stove pipe outside for cleaning I put the brush in the chimney, duct tape a trash bag over the opening, cut a small hole for the cleaning rod, then go to town.
Not at all... Ash should be removed before cleaning and creosote is not flying while cleaning as you saw in the video.
It costs only less than $50 and makes me a life saver
What else can I ask for?
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #17
I got one a few years ago from Amazon since I have a flexible liner and the cap is clamped to the liner... plus like said above I have a 12/12 roof and until a year ago my overhead power was within arms reach of the only place to put a ladder next to the chimney... when I use it I use the cordless drill and turn it slow, the soot just goes straight down with very minimal mess...
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #18
Another happy user. Got one two years ago. Easy and safe. Even if it only lasted one cleaning I would buy another, but there is no descernable wear so far. Used it twice.
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #19
Wife asked me just the other day if we should get the chimney cleaned. I told her the same thing I told her last time, about 10 years ago.
NO!!
We haven't burned more than a dozen fires since 1984 when we moved into the house. She watches too many TV commercials.
/ Chimney cleaning Kit.. You must have if you are old than 50...👍👍 #20
As you can see in the photo, there's no way to clean the SS chimney from the roof, nor would I want to given the steepness (the brick chimney is no longer in use), but there's a cleanout cover on the bottom. I'll just throw a tarp on the ground and use an 8" round brush with fiberglass rods to clean it and all the mess stays outside. Inside pipes come apart easily enough to bring outside, but generally stay relatively creosote-free.
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2003 Ford F-150...
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
