Oil & Fuel L2502 smokes really bad at cold start
   / L2502 smokes really bad at cold start #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
Even at not so cold 5 celcuis or 35 f, my new L2502 runs rought and smokes like crazy for about 3 minutes. There will be no mice or rats survive in my garage.
Anybody else have this trouble?
   / L2502 smokes really bad at cold start #2
Both mine smoke a bit when cold. Nature of a diesel that you cannot get away from. Incomplete combustion in cold cylinders.
   / L2502 smokes really bad at cold start #3
Are you using the glow plugs?
   / L2502 smokes really bad at cold start #4
I thought you was going to force the dealer to take that tractor back…..
My L4740 kubota made a few puffs but this bellows between 1 to 3 minutes.
He gave me the option. It was down 2 litres of udt. One litre to show on stick. He gusnaenteed the tranny and gave me $500. Only 2 hours on it should I don’t think it was hurt.
   / L2502 smokes really bad at cold start #8
I just get a little puff on the l3800 when it starts . I use Power Service fuel Supplement all year long... (white bottle)
  • Good Post
Reactions: JWR
   / L2502 smokes really bad at cold start #9
I mean, with no DPF, that's normal
   / L2502 smokes really bad at cold start #10
Nope, when it is really cold our Kubota will smoke and run rough for about 15 or 20 seconds max after starting. Then it settles down, runs smooth & no more smoke at any constant RPM.
However, it will always blow a gust of black smoke when changing RPM no matter if it is cold or totally warmed up .... always has done that.
   / L2502 smokes really bad at cold start #11
My philosophy is... Where there is smoke, there is fire and that applies to all diesels.
That’s what I was expecting.
Is yours an L2502 or l2501. 25 hp?
I’ll add to my Original post.this is not my video but my tractor acts similar to this. It’s not exceptable.
   / L2502 smokes really bad at cold start #18
Wow sounds like a old biplane....
If you end up finding enough wrong with it, you will get all your money back and the dealer will owe you money!
It’s disappointing. How the hellcan kubota put something like that on the market. The l series tractor is one of their best sellers and they are going the screw then self. It’s not hard to test that it’s pretty obvious. Secondly how could the dealer let it go out the door.
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CATERPILLAR 289D3 SKID STEER (A60429)
2022 CATERPILLAR...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
