Bekaert or Red Brand field fence wire?
/ Bekaert or Red Brand field fence wire? #11
I planning on 10' cross braces. Some of mine will be gate braces as well as corners and ends so I want cross bracing instead of that one horizontal brace. I'm planning on 8' x 330' rolls of fixed knot. Debating on the 12" vs 6" spacing. I'm installing gates now.
/ Bekaert or Red Brand field fence wire? #12
Nice design. But boy that 8’ knotted wire roll fencing is a brute to work with. When I constructed my 8’ deer fence with two stacked rolls of 4’ fence.
/ Bekaert or Red Brand field fence wire? #13
I started out with Red Brand 2x4 horse fence in 200 foot rolls. I was getting them from Lowes for $240 a roll, plus 10% off for my military discount. It's good fencing. Then when everything became hard to find in 2020, I bought whatever I could find, wherever it was sold. Tractor Supply and Atwood's would get a roll or two, and I would buy it as fast as I could. Prices shot up to $330 a roll for OK Brand, which I paid. In the last year, supply has gotten better, but it's still hit or miss if it's in stock at my local stores, or if I have to drive half an hour to an hour to get what I want. Lowes hasn't had much for fencing until recently, and their prices went up to $360 a roll for 200 feet of Red Brand, but OK Brand is down to $299 at Atwood's and Tractor Supply. I just looked online and Tractor Supply is on sale for $269 a roll. I'm buying OK Brand, and except for the red paint, it's the same thing as Red Brand.
I stretch 4 point high tensile barbed wire from corner post to corner post to lay out my wood posts every 100 feet, and my T posts every ten feet. I set all my wood posts in concrete. I've pulled enough wood posts out of the ground with and without concrete to know there is a significant difference with concrete.
I'm not a fan of H bracing. Every H brace is only as strong as it's diagonal bracing. I'm using 2 inch galvanized pipe set in concrete for my diagonal bracing. On long runs, I'll put diagonal braces on my wood posts every 200 feet.
I'm using a Man Saver T post pounder to get all my T posts in the ground. It's really impressed me, and at the end of the day, I'm not dead tired or sore.
If you don't have one, be sure to buy a Clip Bender. I wore my first one out and bought another right away. When I wear this one out, I'll buy another. Nothing works like it does, and once you've used it, you wont' use anything else.
/ Bekaert or Red Brand field fence wire? #14
i have about a mile total of a combo of red and ok brand and i find no difference in quality. whichever is cheaper/in stock when in need. its not easy to tension. i usually do middle first, then bottom, then top. cut all the verticals at the post and wrap them around and tie back into itself, a few loose staples to keep it from sliding up and down. longest run is about 1600 and i just have 2 braces. seems to be just fine. if you are doing top wires, i would install all the feild fencing and top wires at once, then tension them all at the same time. getting them balanced can be a challenge. get a couple tensioners of choice. i just use the classic goldenrod.
/ Bekaert or Red Brand field fence wire? #15
Thanks for the heads up. I haven't put any up yet so I may regret it. I just hate the idea of working with the top section of 2 section fencing or pulling barb wire for the top.
/ Bekaert or Red Brand field fence wire? #16
I'm going to be putting in about 4000 feet of similar fencing. I don't know if 6.5' posts are long enough. 48" wire + a strand of barbed or electric wire above that. I'm going with 7' posts and still have concern about being too short.
/ Bekaert or Red Brand field fence wire? #17
Well for the 8' fence I'm installing 12' 6x6 corner and gate posts, 4' in the ground in concrete and 10' 4v4 line posts 2' in the ground in concrete. I may come between with T posts but haven't decided yet.
/ Bekaert or Red Brand field fence wire? #18
I'm using 6 foot T posts for my 4 foot fence. My soil is red clay, and it holds the T posts in the ground extremely well!!!!
For stretching my fencing, I bought a 4 foot stretcher bar from Kencove. I tried making my own from 2x6's and bolts, but it's nowhere near as good as the one they sell. I use two Come Alongs that I attach to my backhoe with chains to get the best angle to tighten the fencing. I only do two rolls at a time when stretching.
/ Bekaert or Red Brand field fence wire? #19
You also need to find a good crimper to connect each roll of fencing. To me, this is the thing I hate the most. My crimper does the job, but I hate using it. I put two sleeves on the top and bottom wire, and a single sleeve on the other wires.
/ Bekaert or Red Brand field fence wire? #20
I think I'm going to use those small cable clamps to do that or either just put a post in where the joint is.
2013 Infiniti JX35 v SUV (A59231)
2013 Infiniti JX35...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60352)
2012 International...
CFG Industrial H12R (A60463)
CFG Industrial...
Deere 310L (A53317)
Deere 310L (A53317)
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
