Want to buy a sawmill - Talk me out of it!
/ Want to buy a sawmill - Talk me out of it! #1
HawkinsHollow
SE TN
Branson 3015R
I have a couple of big projects coming up, 2 shed builds and a sizable addition on our house plus a few other projects I would like to do down the line. My wife wants a lot of wood accent in our house addition and I want to add a "timber frame" covered deck off the back once we are done with the addition. I am VERY tempted to pull the trigger on a sawmill to mill a lot of this lumber myself. I am leaning towards a Woodland Mill HM126 at about $4200 shipped with a bed extension. Seems like it could pay for itself in short order.
Yes I understand a manual mill is not fast and it is LOTS of work. But I have the space, I have the trees, I have a tractor, I have the money, I am only 49 and in good shape. Honestly, the only thing I DON'T have is tons of free time. But the way I look at it is if I set this mill up well I can go over there and saw a log or 3 per week, blow off some steam and have some nice lumber for my projects.
I have wanted a mill for a long time. I have a friend with a nice Woodmizer hydraulic mill about a mile down the road from me but we can never seem to make time to mill my wood, so I have pretty much given up on that. Which is why I want my own mill so I can just do it for myself.
The way I look at it is if I do not use it enough or I run out of projects to use it on I sell it for a small loss, but still come out ahead in the long run. This is something I have always wanted to try seems like now might be the time.
QUIT trying talking me into one.
:ROFLMAO: You guys are no help. Half the time I post on here someone always tells me it is an AWFUL idea. Where are those guys at when you need them?
/ Want to buy a sawmill - Talk me out of it! #5
I was just talking with my wife about getting one, just no money right now. Have other priorities first.
/ Want to buy a sawmill - Talk me out of it! #6
If you have a use for one, and have the funds, go for it. :)
We haven’t used ours as much as we planned yet, but will be doing so more this coming year. We did add a 7’ extension since this first picture.
I’ve so far milled some oaks and some wild cherry.
And, I’ve used the oak to build some wood working projects like this. It’s only air dried and then we heat treat in a metal cargo container that uses a fan for air circulation and humidity control. Not exactly the most scientific approach but it gets the wood temp up in an attempt to kill any bugs. Whenever we start milling up some pine I’ll need to supplement the heat to get the pitch set in the pine though.
/ Want to buy a sawmill - Talk me out of it! #8
I had a Hudson mill for several years and it was worthwhile both as a hobby and for my own lumber needs. I sold it once I pretty much ran out of projects. I have since than had to hold myself back from buying another one. The Woodland mills are awful tempting. Lots of features that other mills lack at the price.
Make sure you get extension rails, blade sharpener, and the adjustable blade guide. Although you can buy your blades from them I found that blades from Cook's Saw were a better deal.
/ Want to buy a sawmill - Talk me out of it! #9
You are planning to use this for a home addition, how do you plan on drying and curing the wood or boards? Green wood shrinks alot and may be infested. My father had a mill and used it a ton. Much of the pine he built with has beetles and the oak paneling shrank leaving nasty gaps.
/ Want to buy a sawmill - Talk me out of it! #12
It would be a great complement to your tractor and woodlot. Once you get it, do your projects and build a shed for it you will always have it when you need it.
The mill you are looking at is similar to mine and many others; low volume and not something you would want to saw out a house with
However when it comes to framing lumber I can cut the trees and sell them to the mill; then buy planed kiln dried studs for less money.
I am researching that now. I do have a professional drying kiln a couple miles from me that will dry it for $0.15 per board foot. More than likely I will make a solar kiln though.
/ Want to buy a sawmill - Talk me out of it! #14
Cutting is the easy part. Finding a place to sticker the wood out of the rain can be a hassle. Green boards weigh much more if handling by hand. The romance of owning a portable band mill quickly wore off for me. I recently had a guy offer me good money for my Baker mill and I seriously thought about selling. My biggest headache is if the Honda sits for any length of time I can spend half a day removing the carb and cleaning plus trying to remember where all the springs and linkages go.
Yeah, I get that. One advantage I do have is a 12 year old son whom I can employ to help on the mill. My plan is to definitely get all my systems set up well right from the jump so I am not half a$$ing it. Know how I am going to handle waste product and having a good area setup for stacking and stickering. That is one thing my buddy with the hydraulic mill down the road taught me. You are just bashing your head into the wall if you do not have a way to deal with waste and stacking. He does not and he wastes so much time and effort, it's kind of sad.
As far as the Honda is concerned, ethanol or non-ethanol?? I guess that is a question for another thread.
/ Want to buy a sawmill - Talk me out of it! #16
The engine bit is something I am concerned about. I've had good luck with small engines if I run them dry before storing them. That on my mill doesn't have a separate shutoff. Fuel and spark are on the same lever.
/ Want to buy a sawmill - Talk me out of it! #18
Hawkinshollow
Remember a fool and his money are soon parted šŸ˜‚
My attempt at talking you out of buying one šŸ‘
Hawkinshollow
Don't listen to that guy on your right shoulder. Remember, he never let's you have any fun!
/ Want to buy a sawmill - Talk me out of it! #19
sound like a no brainer, the only thing id say is as long as you are not in a rush to get what your wife wants doesn't sound like you have a whole lot of time and it is time consuming especially if you are planning on falling your own trees.
/ Want to buy a sawmill - Talk me out of it! #20
I know 2 people that bought a lower end manual band mill with similar plans. They both came to the conclusion that milling generic construction lumber was too much work. Milling hardwood for woodworking that’s much more valuable was a different story.
2011 Deere 50D (A60462)
2011 Deere 50D...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
2006 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2006 BIG TEX 20...
Hilti TE 2000-AVR Electric Jack Hammer (A60352)
Hilti TE 2000-AVR...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
