Gopher plow
   / Gopher plow
I am not sure on the size of the coulter now I would have to measure it but somewhere between 18-24" I would guess.
You can't see the lower 3/4" bolt in the plow, it is covered by the swing arm, but if the little top bolt shears it pivots on the bottom bolt until it hits a stop between the plates (before crashing the rear tube).
   / Gopher plow #22
Is it possible that something similar to this being used by county tractors in the ditches east of Elk City. They were pulling something looking similar that leaves a small furrow. Between Elk City and all the way past Clinton so more than one county using the same implement all around the ditches. We were working on a house and the front yard is riddled with gopher holes but the tractors lifted the implement out of the ground till it got past their yard then continued in the ditches.
   / Gopher plow
Had it out again the other day, the sand has done a little smoothing over the last decade.
Stainless on the drive wheel seems to have worked out too.
No sheared bolts but a ‘48 8N isn’t a power house either. If you operate one of these and do snag something, when you back up, you must clear the drop tube. Note: that piece of bailing wire in the hole right above the top link, on the 3 pt. If you don’t, dirt can pack the hole the seeds are suppose to drop through, into the tunnel.
   / Gopher plow #24
The torque of a gas engine (none) and no low range, severely limits the usefulness of the N series. Before WW2 most popular tractors here were Lanz Bulldog hotbulbs. They didnt have many gears, but once they stalled, you pushed the clutch, waited for the flywheel to pick up speed, and then have another yank at it, which lasted several yards, so when you were stuck, you'd ask the neighbour with the Lanz and not the one with the Ferguson TEF...
Lanz eventually faded, they outlasted the operator. It wasnt just good, but also harsh on the operator. In 58 or 59 they were bought out by John Deere which builds 5 and 6 series tractors in the Mannheim plant till this day.
   / Gopher plow #25
Photobucket and their banners over the photos
   / Gopher plow
   / Gopher plow #27
Thank you. That's SO MUCH better. That's an interesting contraption. I'm currently dealing with Moles on my 3/4 fenced acre, tearing my place up, so your post got my attention.
2024 Quality Steel Deck Over Tilt Trailer (A59814)
2024 Quality Steel...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
