Rotting metal floor in horse muck trailer
/ Rotting metal floor in horse muck trailer #1
Spydertractor
Ford 6600
Hi all, I am looking for some help with the best way to replace a metal floor on a tractor trailer that is used to dispose of horse manure. As is usual in these situations, the muck is loaded daily onto the trailer but as we only have two horses it may take a couple of months or more before it is emptied so there is a continuous pool of effluent that seems to rot the exposed metal parts of the trailer quickly and effectively.
Has anyone any experience of alternative materials for the floor and sides? Wood? Stainless steel? Plastic??
Any suggestions gratefully received!
Best wishes
/ Rotting metal floor in horse muck trailer #2
I would simply replace the floor with whatever material you’re comfortable working in. Metal if that’s your cuppa tea or wood if that is your strong point. I would then obtain some plastic 55 gallon drums and cut them in half. Attach some rope loops to make up Muck buckets that are easy to slide to the end of the trailer to dump.
Storing the trailer undercover, or with the tongue elevated to prevent water from pooling in the trailer, would help to preserve the floor.
/ Rotting metal floor in horse muck trailer #3
I have horses too. Assumed a dump trailer vs a spreader. For any trailer longevity, the muck has to be separated from metal or wood. A liquid tight coating of epoxy paint would serve well. Any damage to the coating renders it useless... As in no shovels to contact the coating.
Thanks guys, your responses are very helpful.
/ Rotting metal floor in horse muck trailer #5
I'd say you'd have to use either some good stainless steel or a type of plastic to avoid corrosion in that situation. Since that much stainless is probably extremely expensive perhaps look into converting the flooring to PVC sheeting. Something like this:
No idea if the PVC has the structural strength for what you're loading... Just offering an idea.
/ Rotting metal floor in horse muck trailer #6
Our horses I pile muck from stalls and paddock area down off of an embankment. When I want to move it I load-move-wash off trailer. I'm thinking otherwise storing all the manure in anything would rot or cause corrosion...fresh wet manure & ammonia urine. Ideal would be a concrete manure pit.
Why not pile it up somewhere outside then load & haul it off as needed?
/ Rotting metal floor in horse muck trailer #7
That's what my neighbor does. He has an old Deere 2210 garden tractor with a loader. Hauls a bucket load out back a ways and dumps it. His pile now, after several years is about 4' high and at least 50' long.
/ Rotting metal floor in horse muck trailer #8
That's what my neighbor with 5 horses does. His pile grows faster than that. That stuff makes some great compost eventually! But it comes with a lot of weed seeds.
Thanks for these suggestions. Unfortunately I don’t have a front end bucket so I have no way of getting the stuff on to the trailer other than a wheelbarrow so I would rather load it as it comes out the stable but I get that that is far from ideal.
I think I might try some chequer-plate alloy (reduced slipping) on top of the existing metal floor (that is mostly still intact) with a layer of bitumen between to try to stop further deterioration of the old metal floor.
Does that sound bonkers?
Might add some epoxy paint on top for good measure.
/ Rotting metal floor in horse muck trailer #11
Get an old drop-in plastic pickup bed liner. Set it in the trailer, adding braces and supports as needed.
Bruce
207281 (A52708)
207281 (A52708)
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
