Tough on Husky chains today... ?
/ Tough on Husky chains today... ? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
Since it was going to be in the 40's today, I went after the three trees today, that I had taken down last week. A big Ponderosa pine, an Ash and a Poplar. The pine was going to the burn pile, so I lopped the pieces into 8' or so and dragged them off. The Ash and Poplar were cut into stove lengths and carted off in the tractor loader. I had issues with chains on both my Husky's 345 and 455 Rancher. When the chains loosen up, if I'm not careful and catch a side twig or similar, the chains pop off. This has happened from time to time with all my sawing experience (30+ years), so I wasn't surprised. What happened today, pissed me off. On sepparate cases, they each spit the chain off and I COULD NOT get them to run the chains after getting them back on. The chain would lock up and not spin. Husky chain, both new(ish). The drive lugs on both got chewed up. I'll need to file/grind 'em back smooth to see if they are salvagable. I put another chain on the 345 and continued, but the 455 is new and I didn't have another chain, so that one got parked. I've kicked off Oregon chain w/o issue in the past, and honestly Oregon has been my brand of choice. Are Husky chain lugs that soft now?
/ Tough on Husky chains today... ? #2
I’ve had that happen with several chains. I’ve got Husqvarna, Stihl, and Oregon chain. They’re all about the same.
/ Tough on Husky chains today... ? #3
Common on thrown chains.
If not to bad you can set loose and make them work themselves back in groove. Be careful.
Some you take a file and remove the rough nicked spots on chain. Good to go then.
See it alot here on folks that run to loose of chain and throwing them.
Thanks. They're not mangled bad, just nicked up enough to not slide. A file will work best, but it'll be tedious. I wonder if I can use (first must find) my dremel, with a small sanding disk?
/ Tough on Husky chains today... ? #5
I have removed the burrs with a dremel hundreds of times on customer chains.
It's all Oregon chain even though Stihl won't tell you that.
/ Tough on Husky chains today... ? #6
Like guy above said dremel. But thats when back in shop.
File you most times have with you out cutting. Round and maybe flat.
They're back in the shop. Is there a trick to keeping the chains secure, flat and steady, while filing?
/ Tough on Husky chains today... ? #8
You need to check the bars and make sure the rails aren't damaged as well and as far a jumping chains, I rarely have that happen as I mind the tension constantly. Don't have a clue who makes Husky chain loops but I'd say they are Oregon.
One thing to keep in mind and that is, if you change the drive profile on the chain drivers, you'll quickly eat up the drive sprocket on the clutch end of the saw. The drivers are matched to the drive sprocket profile and in reality that is a consumable item anyway. I don't have any Husky saws but on my Echo's and Stihl's the sprocket and it's needle bearing are replaceable items. Just my 2 cents...
Thanks. Since I've never done anything to the drives on my chains, I'm sure that may have contributed to premature bar wear, of which I've changed several. I've just never seen/felt any damage there before. That's what got my attention here now.
I have the Oregon drive sprocket system on the smaller 345. Since the 455 is almost brand new, I haven't touched that yet. Both have roller bearing drives that are supposed to be oiled/greased, but I don't know how to get in there w/out taking the drive/clutch off.
/ Tough on Husky chains today... ? #10
Needle, not roller and it depends on the model and how the drive sprocket is attached to the clutch drum itself. On my saws it's secured with a 'C' clip except my little Echo top handles and with that one, the drive sprocket and the clutch drum are one assembly so you have to replace it as an assembly.
/ Tough on Husky chains today... ? #11
I wonder if you have the tendency to run your chains too loose? I have the same tendency and lose a chain here & there.
I keep a scrench with me and try to keep 'em tight, but "stuff" happens.
/ Tough on Husky chains today... ? #13
Stihl makes their own chains in Wil Switzerland. Until Husqvarna started making some of their own chains, Stihl was the only chainsaw manufacturer making their own chains.
/ Tough on Husky chains today... ? #14
I have been told by more than one stihl dealer that is true until I had them set the Oregon catalog next to the Stihl catalog on the counter. The Stihl Chain and the Oregon chain were the exact cut and paste description including the font and letter spacing when Oregon patented their blue cutter and X-grind technology. And I have personally witnessed more than one Oregon factory rep admit that it was Oregon chain off the record.
One major difference was you couldn't use Oregon tie straps to repair Stihl chain because the Stihl chain used smaller rivet diameters. I have been told that is no longer true and the Oregon tie straps fit Stihl Chain now. Stihl may of been using their own specifications but it was Oregon chain. And there are still enough similarities between the chains even today that I am not convinced there isn't some Oregon input.
/ Tough on Husky chains today... ? #15
I make chain. Wasnt the rivets on 3/8 050.
What I seen was say a 050 drive link chain in stihl was 063 at top of drive link where goes together. A 050 chain in Oregon was 058 at top. So if you tried to use a oregon preset and tie strap on a stihl drive link it would be to tight to move.
/ Tough on Husky chains today... ? #16
Husky started making their own chain way back in 2017. Some of the lesser chains prob still oregon.
For the first time, there are original Husqvarna saw chains, and they are made where it all once started – in Huskvarna, Sweden. Why, you might wonder. Well, the story actually starts at the end. Through all our research and development, making your output the highest possible has been the overarching goal.
For decades, Husqvarna has been one of the world’s most respected chainsaw brands. There is no simple explanation as to why that is. But a major key to the brand’s success has always been the constant focus on the user’s output. Anyone picking up a Husqvarna chainsaw should be able to count on getting the best possible returns.
“Manufacturing our own saw chains is not something we have embarked on just for fun, or because we felt like it,” Lead Engineer Hans-Åke Sundberg says, rather seriously. “Through all the years, we have never stopped improving our users’ experience and output. The cutting equipment plays an extremely important role in that.”
More than just high quality
The dream of an original Husqvarna saw chain has been with us for a long time,” Global Product Manager Mattias Karlsson adds. “Making it a reality, however, has taken a huge amount of planning, research and strategic thinking. There’s no trial and error in a Husqvarna product launch.”
Naturally, the Husqvarna saw chains had to meet the high quality of the Husqvarna chainsaws. But for most users, Husqvarna stands for more than just robustness and performance – it’s about trust.
“You must be able to trust that the machine you have invested in will give you the highest efficiency and the best results,” Karlsson continued. “Living up to those expectations requires considerable commitment from the manufacturer.”
At the heart of Husqvarna
The saw chain factory was built from scratch over the course of several years. Its strategic location, right beside the original chainsaw factory in Huskvarna, Sweden, underlines its importance – it is right at the heart of the brand.
Inside this advanced and modern saw chain factory, there is a rich variety of complex machinery, winding production lines and elaborate processes. Not one part of the saw chain comes ready from any supplier – it’s all made here, from raw steel to finished product. In addition to the factory, Husqvarna realized that they also had to build an adjacent little sawmill to be able to continuously test prototypes.
Edge Campaign Photo
Developed backwards
“The single most important part of a logger’s every day is the cubic meter output,” said Sundberg. “We worked backwards from there. We identified the right product features, the right manufacturing, the right materials, the right competence, and the right mindset for a long-term venture into a new field.”
The X-Cut saw chain has been tested and fine-tuned for about two years now. Following classic Husqvarna procedures, a combination of lab tests and test runs in different environments has been crucial for perfecting its features, refining its design and ensuring its quality.
Ready for action
So, from the end to the beginning and back to the end, we have finally arrived. After years of planning, research, development, testing, collaboration with loggers, and some more testing, the first Husqvarna saw chain is ready to be mounted on your chainsaw. It’s ready for hard, uninterrupted work, ready to give you maximum efficiency and output – ready when you are.
/ Tough on Husky chains today... ? #17
I used Oregon chain, that's what my Husky dealer sell. New chains will always stretch more then a used one since the used one is already stretch plus the wear on the bar will cause it to loosen up as well. It sound like you didn't have the tool to remove the cover and loosen up the bar to make sure the chain was properly on the sprocket?
/ Tough on Husky chains today... ? #18
Two different things. The tie straps come designed to fit .050 .058, and .063 drive thickness chain. Stihl traditionally always used .063. The issue was the diameter of the rivet on the Oregon tie strap wouldn't fit into the hole on the Stihl chain drive link.
If you reamed the holes in the Stihl Drive links the Oregon tie straps would work. Not saying it is a good idea.
/ Tough on Husky chains today... ? #19
Told you what I saw on 3/8 050 chain. Stihl and Oregon.
Never seen your issue you been TOLD on 3/8 050 here.
Do you even take chains apart or make chains or just rely on dealer info they tell you?
Guess I could pull both out again and check. But not feeling the need.
I know what works for me.
/ Tough on Husky chains today... ? #20
Only time I ran into something like you describe was on .404 chains. Both Oregon of different series.
Guy brought some 404 for me to shorten for him. He brought his own presets. They were wrong for the oregon series chain he had. Rivet are was way to small and wallow in drive link.
Here is right preset I had for use on the 404.
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
