Removing high tensile fence wire to re-use?
   / Removing high tensile fence wire to re-use? #11
Here are some pics. I dug the thing out this morning. I used hairpins instead of 1/4" bolts as I had described earlier, getting old is tough - memory not as sharp as it used to be. The uprights are screwed to the plywood with 3" deck screws from underneath. The 4 holes in the plywood are for using tent stakes to hold it to the ground or you could screw it down to something else. A good, simple tool from scraps I had lying around.
   / Removing high tensile fence wire to re-use? #12
I think you could wind a softer wire like smooth twisted or barbed wire that tight, but it wouldn’t work for high tensile wire. Something the makes a large loop wind like a spinning Jenny is what is needed for high tensile wire.
   / Removing high tensile fence wire to re-use? #13
That IS a spool of hi tensile steel wire, not aluminum wire.
   / Removing high tensile fence wire to re-use? #14
Then I think it’s overwound. How does it spool out again after being wound so tight? All of that wire comes in large diameter coils to avoid kinking.
   / Removing high tensile fence wire to re-use? #15
This Spinning Jenny is what I use. Works best with my wife helping to keep a little back tension as I wind it up. Tye wrap the bundle and store it for reuse.
Added this as it is what makes rewinding the wire easy. And goes along with the previous post I made.
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
