rockinbbar
Gold Member
- Joined
- Nov 11, 2015
- Messages
- 412
- Location
- South Texas
- Tractor
- New Holland Powerstar 120, Powerstar 75, New Holland c245
I've been cussing CNH products for years for not making a 3 point hitch system that comes up high enough to move hay bales reliably.
The issue is I can't adjust the top link to lift the bale high enough if the bale isn't really firm, or had a somewhat wallowed out center from being moved.
Here's an example. This is as much lift as I can get without cranking on the manual toplink after I've speared the bale...
If I leave the manual top link adjusted to lift higher, the angle of the spear is too severe to run into the bale.
A hydraulic top link ought to solve this, shouldn't it?
Have any of you used a hydraulic top link to get the 3 pt hitch load higher?
Just seeking input before I order a new hydraulic top link. Preferred manufacturer?
Thanks!
Thanks!
