Keweenaw snow photos
/ Keweenaw snow photos #981
I hope this year is a good one for you folks ArlyA
Thought I should post this here. Its up in the peninsula, about 15 miles from where we reside.
/ Keweenaw snow photos #987
That’s like wow
/ Keweenaw snow photos #988
32' is really unimaginable.
1978-79 isn't that long ago, some pictures (even if it's a picture of a picture) would be fun to see if you have the time. 👍
/ Keweenaw snow photos #989
I grew up in the far west suburbs of Chicago. It seems like that same winter, 78-79, we had a lot of snow then.
/ Keweenaw snow photos #990
Well, it's always impressive until you realize that it's the total snowfall for the season, not how much was on the ground at one time. The past couple of years that I've been monitoring the snow depths on my land in the UP, the most I've seen accumulated at one time was around 40-48".
That's still impressive all things considered, especially when you get your sled stuck 3/4 of a mile back in the woods from the nearest road, it's 15 minutes to sunset, you're alone, and the temperature is -5°F and dropping...
/ Keweenaw snow photos #991
....but you must still have some killer snow banks from plowed areas.👍
It does surprise me that you have that much melting/settling during the season to only accumulate 48". You must get a lot of "primo" light powdery snowfalls.
/ Keweenaw snow photos #993
I live 30 miles south of the sign. Our winter snow amounts are lower than average now. When you get 300 inches, the snow in the fields is usually around 3-4 feet, because of settling. Snow weight and mini thaws. Other wise nobody could move up here.
/ Keweenaw snow photos #994
And especially in the late fall/early winter when there is a lot of snow on unfrozen ground, it melts from the bottom. The snow insulates the ground and slows ir from freezing, so it's not uncommon to still have cold temperatures in the early winter and lose a lot of the snowpack. Taking the air out compacts it, slows snowpack depletion, and reduces insulating capacity allowing the ground to freeze.
When it's really cold in the winter, there is still a significant amount of snowpack loss from sublimation, where the snow doesn't melt, but goes directly from a frozen to gaseous state.
When I lived in the high country out west, it was not uncommon to get 2-3 feet of soft fluffy powder, and by afternoon there'd be 6" of snow on the ground from settling and sublimation. If you get to work early enough in the day, you can clear your driveway or sidewalk with a leaf blower.
/ Keweenaw snow photos #995
Doesn't the ground not freeze under the snow ? Jon
It doesn't freeze. Cools off yes but with snow cover, never freezes. I'd guess it does get close to 32.
/ Keweenaw snow photos #997
If there's not a deep snowpack and the temperatures remain below freezing for a week or two, then yes the ground will freeze - sub zero temps help. But it takes a long time if there's a substantial amount of snow on unfrozen ground.
This is why animals and birds (like Ruffed Grouse) burrow in the snow at night - it never gets any colder than 32°F under the snow even if the air temp is -30°F, and the snow insulates them.
Edit: it DOES get colder than 32°F under the snow, but as the snow is an insulator the birds stay quite warm in their snow roosts. Same principle as an igloo.
and where does swingoak live?
/ Keweenaw snow photos #999
And that ground temperature of 33 degrees help pack the snow and condense the snow amount on the ground over the course of the winter. Jon
/ Keweenaw snow photos #1,000
Here's what I know about snow covering the ground from various experiences you never drove snowmobiles, ATVs plow or even walk over your septic drain field or sewer line it will freeze cuz you compacted the snow there by taking away it's insulating properties. The yearly frost line is measured on plowed county roads up north it's been over 4' even in more recent yrs, from building up there i had to put footers/ sono tubes etc down at least 4.5' Early snow storms, most diehard winter sports enthusiasts want it to melt cuz the ground isn't frozen yet and prevents a good base from forming.
2020 ISUZU NQR (A60736)
2020 ISUZU NQR...
2025 80in Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
2004 VOLVO EC290B LC EXCAVATOR (A62129)
2004 VOLVO EC290B...
Deere 310SK (A57148)
IGERSOLL-RAND AIR COMPRESOR (A60736)
IGERSOLL-RAND AIR...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
