etpm
- Joined
- Jun 30, 2021
- Messages
- 2,358
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I don't know how the latch on your coupler works but maybe you are experiencing the same problem I have had with a cheap trailer I own. The lever that must be pushed down to trap the ball pulls up a piece inside the hitch when it is pushed down. First of all this mechanism must be properly adjusted to trap the ball but also release it. But even when properly adjusted what often happens is that even though the lever is up it does not allow the piece inside to drop down. This is because the bolt attached to the lever does not drop down when the lever is raised. So the lever must be raised and then while still raised it must be pushed down such that the bolt is pushed down. This will let the piece inside the hitch drop and thus release the ball. I know, my description of the process is confusing but if you look at your hitch you will see what I mean. Pull the lever up and while in the raised position push straight down in line with the bolt. I'm sure someone will chime in with a better description of what I am trying to say. There should be a spring that does the job for you but sometimes it is either weak, missing, or things just get hung up. The spring is hidden in the hitch so you can't see if it is missing unless you look at the underside of the hitch. Oh, i saw after I made my post the Bruce posted a picture of the hitch mechanism. I shoulda done this. Bruce's post makes things much clearer.
Eric
Eric
