Coulter for disc hiller
/ Coulter for disc hiller #22
Something like this; of coarse I'm sure there are cheaper; but you've got a back mounting bracket, that could be U bolted around a vertical down rod from your frame,
Heck, I didn't read description, but if it's a pair; then just all thread from one to the other, and run dual bare wheels? Pinching your down leg between the two sets of mounting flanges
Something like this; of coarse I'm sure there are cheaper; but you've got a back mounting bracket, that could be U bolted around a vertical down rod from your frame, View attachment 832468
I like the dually idea. Also discovered that you can buy weld in trailer spindles w/hubs. Decision comes down to matching the hub to either a car wheel or trailer wheel. These trailer hubs are 4 on 4 like a Blanton hub but I think the pilot diameter is bigger than any coulter blades I’ve seen.
On with the shopping!
I bought the trailer axle kit and found 14” flat coulter blade on eBay.
I looked for trailer wheels on Craigslist, etc but didnt find anything cheap enough for my taste. I wasn’t sure what the offset (horizontal distance outside of rim to plane of bolt circle) on a trailer wheel, so I was thinking that the axle might be too short and the rim would interfere with into the vertical support. Flat blade avoids that. If I find a cheep rim, I’ll see if that will fit
The coulter bolt circle and bolt hole sizes are metric and off a bit, but the pilot hole diameter is close. I’ll need to lay out and drill new bolt holes, but I can probably get it to work. A little bit of runout is not likely to matter much at 1 mph
Thanks for all the help. Pics to follow in a week or so!
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
2022 Horizon Trailer (A60352)
2022 Horizon...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
2004 Bulter Pole BP-2080-A T/A Pole Trailer (A60352)
2004 Bulter Pole...
60'' Skid steer bucket (A61567)
60'' Skid steer...
