What's the best 12V DC power source for my fueling station?
/ What's the best 12V DC power source for my fueling station? #51
OK, here's a related question:
If I'm powering the pump with an independent aux battery, is the inline fuse really necessary or not?
I have one on mine.
If you raised tank up 5-6 feet you could gravity fill. No electricity or anything. All you would need would be a few steps for delivery guy.
My excavator neighbor/friend's tank is like that and he fills his truck, Bobcat, track hoe, etc. that way. No pump or power.
Thanks, Fuddyduddy1952... [great handle, by the way, and a great year for some things, too].
Yeah, me and Sir Isaac Newton get the gravity thing, but am I soon gonna raise a +half-full 500 gal. tank 5-6 feet? Probably not; there's other fish to fry. I'll save that project for when the big grid goes down, or when my aux battery tanks and I don't have another one, and when the asteroid belt moves and makes the sun so dim that I can't charge it with solar, or when ... Uh - in the immortal words of Pres. H.W.B: "Naht gohnna daht..."
But I get it, and you said it best: simplicity. So I do have one of those manual crank jobs sitting new in a box, just in case.
I have one on mine.
Yeah, most everybody does - and that seems to be the stock, default answer. But in the application I described, is it really necessary? I mean, in reality, what the heck's gonna happen in between my charged-up motorcycle battery and the motor of my GPI pump that's somehow gonna burn up 18-20 ga. multi-strand copper wire or trash the motor?
/ What's the best 12V DC power source for my fueling station? #54
Ya, probably nothing. My 12 v pump came with an inline weatherproof fuse on the red clamp cable. im sure thats to meet UL Listing.
Exactly.
I have inline weatherproof fuses new in stock that ain't never been used yet. And they have their place.
But since my fuel station is outside 24/7, getting blasted by the prevailings and whatever they bring, and since I have - on rare occasions - had fuses, both the old kind and the newer kind - go bad for no blessed reason other than 'its time had come', and if simplicity is indeed the thing, than why put one in?
/ What's the best 12V DC power source for my fueling station? #56
The simple reason for a fuse to protect the wire in case the pump or the wiring gets shorted, pump in a locked rotor mode, switch shorting out.
If it does that wire will over heat melt the insulation and be a hazard to any fuel it gets to. You are much better off with a fuse close to the battery connection.
OK, thanks for that, LouNY.
And thanks once again to TBN friends for your widely varied suggestions and good opinions. Yer the best.
~Lefty7
2022 Caterpillar 289D3 (A60462)
2022 Caterpillar...
2021 Polaris General XP 4 1000 4x4 Side by Side (A60352)
2021 Polaris...
Ford 8340 (A53317)
Ford 8340 (A53317)
New/Unused Quick Attach Auger with Three Bits (A61166)
New/Unused Quick...
John Deere 24'' Backhoe Bucket (A60463)
John Deere 24''...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
