Homemade wooden snowplow - thoughts?
   / Homemade wooden snowplow - thoughts? #11
I have a Kubota MX6000 cab tractor. Normally I use a 7' rear blade for snow plowing. However, it is a pain to be looking behind you all the time. What do you guys think of making a wooden front plow?
Here's what I'm thinking:
1.) Buy a 1/4" SSQA metal plate
2.) Buy a 4x8' sheet of 5/8" flooring plywood ; cut it in half the long way for two sheets of 2' x 8'
3.) Using large thick washers and heavy duty bolts, bolt the doubled-up sheets of plywood to the SSQA plate. Next, screw a couple of 2x4x8 boards to the plywood "plow" just above and below the plate, for some additional rigidity.
4.) Use a couple of pieces of angle iron 8' long - one on the back and one on the top, bolted together through the wood at the bottom, as a cutting edge of sorts and to protect the wood.
5.) Paint everything for a bit of waterproofing effect
Obviously this "plow" might now last for more than a season or two, but the only thing needing to be replaced would be the wood. It seems like minimal effort to have a functioning front plow. A couple of wooden wings on the front would essentially create a snow pusher. The whole setup would be light enough to where the wood would just break before any loader arms got bent or anything like that, but still heavy enough to put the loader in "float" and scrape the snow.
I'm open to suggestions or criticisms and thoughts. Just an idea I had running through my head.
I'd find a used truck snowplow for a few hundred bucks and mount that to your SSQA. Maybe even hook up the hydraulics.
I have a 60" power angle snow blade on my FEL arms on my little PowerTrac PT425. Works great!
   / Homemade wooden snowplow - thoughts? #12
I have an old floor timber from my cabin/work shed. I gripped it with my grapple and tried to use it. Sure glad I paid nothing for it. It did not work well at all.
   / Homemade wooden snowplow - thoughts? #13
What I do with my MX6000 works great and it’s a cheap option. I installed some edge tamers to my loader bucket and then turn my rear blade 180 degrees so it won’t pick up the road gravel. With the bucket pushing the bulk of the snow and my 8’ rear blade angled to clean the road it works great.
   / Homemade wooden snowplow - thoughts? #14
Is this home made wood plow also not going to be a floating design?
   / Homemade wooden snowplow - thoughts? #15
Frozen snowbank could be hard wooden plow.
   / Homemade wooden snowplow - thoughts? #16
1965 I was 9 years old, Dad bought me a 1950 Farmall Cub. Wasn't a big tractor, but better than the crappy little snow blower. I soon was clearing six driveways in VT. It was a big job with the anemic blower.
Plow had two push rods made of Hardhack (Hop Hornbeam). They bolted at front to 3" x 1/4" Angle iron. Three fir planks made up the blade. It was held centered by a L shaped square tube item that fastened in the tractor's implement mounts behind the front axle. This passed through a square hole in a 2 x 12 crossmember bolted through the push rods. Lifting was with chains to the tractors hydraulic rocker arms.
It was an improvement over the snow blower, though slow, it was less a problem when I was that young.
At 16 I had a Jeep & bought an old plow to fit to it. Ability to angle the blade speeded up the process of plowing. Used that 12 years until the frame rusted away. Then it was an 8' Fisher on a Jeep full sized Cherokee. 360 V8, four speed & locker in rear, with tire chains, it was a real plow rig!
   / Homemade wooden snowplow - thoughts? #17
Mine on a 1950 Farmall Cub would occasionally break the bottom plank. Neighbor made me shoes of 14 gauge flat stock to weld up & bolt on helped a lot. Eventually replaced the bottom plank with American Elm. Never broke a plank again!
   / Homemade wooden snowplow - thoughts? #18
A wooden snowplow? Maybe trade-in one of those bad ass powerstrokes and buy yourself a real snowplow.
:ROFLMAO:
:ROFLMAO:
The old F-550 has a v-plow and I also have a newer GMC3500 gas dump with a plow as well. I do my driveway and a couple neighboring driveways which are right. The tractor is more maneuverable than the plow trucks in tight quarters and can stack higher. Plus I keep the plow trucks at my shop which is a couple miles away.
   / Homemade wooden snowplow - thoughts? #20
We operate a 6ft plow on our Outlander atv (6x6) and love it. Myself, I'd not waste my time on wood plows.
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
2015 Komatsu WA380-8 Wheel Loader, S/N A74124, PIN# KMTWA130CFNA74124, Diesel Engine, Komatsu WA380 (A59076)
2015 Komatsu...
2019 John Deere 35G (A55272)
2019 John Deere...
