"Emergency heat" from oil-filled space heaters - advice please
/ "Emergency heat" from oil-filled space heaters - advice please #21
There are several heaters made to leave in boats that turn on about 35 degrees and off at 40. They are made to be used in bilges that can contain dangerous fumes. Supposed to be fire proof by design. BUT, they are expensive.
Check out www.westmarine.com and search heaters.
What we always used in a well house was a 100-watt light bulb plugged into a temperature sensing plug. Worked well below zero.
RSKY
/ "Emergency heat" from oil-filled space heaters - advice please #22
..... However I don't think I'd want to leave them unattended for extended periods of time.
I had a space heater catch fire in my house.
No way would I leave anything of these type heaters plugged in, in a non-occupied house.
/ "Emergency heat" from oil-filled space heaters - advice please #23
I hear all the concern about space heaters being used in an non-occupied house.
Brings me to the question if one of these catches the house on fire unless one is sitting there watching it with a fire extinguisher in hand what difference will it make other then the danger and difficulty of getting people safely out of the home.
In an unoccupied home with it placed in the center of a room with no animals or kids or seniors to knock it over or knock something flammable into it, it will be less dangerous then in an occupied home.
As far as the oil filled ones if concerned about a leak set them in a steel pan or tray as a catch basin.
The simple dial adjust ones will cycle themselves on and off to maintain a room temperature or just use a freeze thermostat to turn them on/off.
such as this or the cheaper ones from Amazon;
We have used the "milk house" electric heaters for many years in milk house to prevent freezing.
They are used all night long "unattended" do we worry at times? Yes, but I'm not going to sleep out there in the winter!!!
They also last longer. I have one I've used to heat a small building for 15 years or longer. I have it plugged into a space heater thermostat and it maintains a steady 50 degrees when I'm not around to feed the wood stove.
That's about what I'm looking for, but even lower temps.
Again, what brand model?
For my application I'm not looking for 50°F, 40°F would be fine, if I can set it that low. What space heater thermostat do you use in case the ones I want can't control down to 40°F?
/ "Emergency heat" from oil-filled space heaters - advice please #25
Based on personal experience with my grandparents unoccupied home near my parents home on the farm I can say we tried all sorts of things.
Bottom line as many have said here either winterize the house...drain all water, blowing out lines or install a furnace. To keep pipes from freezing you'd have to have space heaters all over. If something were to happen I doubt any insurance company would pay.
My grandparents home without heat was devastating, wallpaper peeling, mold, etc.
Number 1 is a good leak proof roof.
Number 2 is keeping it at least 50°F.
My Dad (rip) decided to winterize, drained everything turning heat off. Within a year house really went downhill.
My 2c.
/ "Emergency heat" from oil-filled space heaters - advice please #27
May I ask what is your preference for wanting a space heater instead of temporiarly winterizing the pipes until the furnace can be repaired or replaced? Every space heater user manual I've seen says not to use them as anything but supplemental heaters
/ "Emergency heat" from oil-filled space heaters - advice please #28
I had a similar issue with a remote cabin. For extended periods I shut off the water and drained the lines. For shorter uninhabited periods I installed a PTAC unit (hotel type heat pump). It automatically comes on at 40 degrees even if left turned off. Another alternative I considered was a window type A/C unit with heat pump, which is similar to the large PTAC but doesn’t require cutting a big hole in the wall. Not cheap but somewhat efficient. And safe. I also leave all cabinets doors open that contain plumbing.
Preference is because that's what my son and my BIL recommended. Plus I have a large room (~13x20) upstairs that could sometimes use a little extra heat, it's presently my wife's craftroom.
I read the manual and could not find anything about only using for supplemental heat.
I did find a section
This appliance is not intended for use in bathrooms, laundry areas, or similar indoor locations.
And warnings about flammables, etc.
/ "Emergency heat" from oil-filled space heaters - advice please #30
I am all for winterizing over heating, but if you heat, remember that pipes behind walls and under floors will get colder than the rooms. I suspect that so enticing set for 40F may not keep pipes at a distance above freezing.
Those milk house controls are great for items that are exposed in the milk house, which are also usually made of non-flammable materials like concrete...
Net, net, I think that you are going to spend more than a fair bit of money on enough heaters now, and enough may not be obvious until afterwards.
Whatever you do, please shut off and drain the pipes as much as possible, including toilet tanks. Cheap, cheap insurance.
All the best,
Peter
Hydraulic Sweeper Skid Steer Attachment (A59317)
Hydraulic Sweeper...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
New/Unused Electric Golf Cart (A61166)
New/Unused...
72in Skid Steer Fork (A59317)
72in Skid Steer...
2017 Case CX145D (A60462)
2017 Case CX145D...
207274 (A52708)
207274 (A52708)
