I don't want to drill my Loader mount bracket.... does it actually matter?
   / I don't want to drill my Loader mount bracket.... does it actually matter? #11
Could you make a bracket to attach it to the area where there are two bolts already?
That's what I was wondering. There is already a bracket with two bolts holding what looks like a piece of angle iron. I'd clap about a piece of larger angle iron on top of what you show in the photo and then work with that.
I wouldn't add any extra stress to those loader ears.
rScotty
rScotty
its unusable, That part stays with the tractor with the loader disconnected.
   / I don't want to drill my Loader mount bracket.... does it actually matter? #13
You are overthinking it. Just drill and tap it.
On my kubota, I actually did my diverter on the inside of the loader arm itself, so its a little more protected. And put me closer to where I needed to run plumbing so I didnt have hoses sticking outside the loader frame, which could be in harms way in the woods
   / I don't want to drill my Loader mount bracket.... does it actually matter? #14
I bought a diverter valve kit for my mahindra, it requires drilling a mount bracket into the loader support bracket, this bothers me, even though there are holes already in it. Am I worried about nothing, really would like someone who deals with stresses to tell me I am worried about nothing.
what else am I going to do? I have the ability to make a non penetrating mount via 3d printing and cad design, it will take me several hours of design, and some filament, but, I don't like to have 3d printers solve everything if there is literally no reason. and there are several negatives...
Can you guys calm my nerves, I don't plan to ever take it off, I bought a grapple, and need it terribly. photo's attached,
Ignore the missing bolt, it was taken out for the design of the non penetrating.
@kennyd this is the artillian diverter, which i think your familiar with.
I installed a diverter valve on my MF 1755m and used this mounting bracket. Worked great for me & no holes to drill. DV50 & DV90 Hydraulic Diverter Valve Dual Clamp Mounting Bracket - Summit Hydraulics
I'm an engineer, its my job to overthink everything, I also have this thread running in parallel on a structural engineering forum, and they seem to agree its a non issue. do you have a photo of your install?
   / I don't want to drill my Loader mount bracket.... does it actually matter? #17
Link to my diverter install is in my signature with alot of pics. (not sure if you can see a signature line on mobile, but I know you can on desktop)
you have a photo of the bolts on the outside of the arm?
   / I don't want to drill my Loader mount bracket.... does it actually matter? #19
I have a similar dilemma, as I want to fabricate a chainsaw mount to affix on my loader support frame. Was planning to drill a couple 1/4-20 holes and tap, as I really cant imagine the support frame is at a critical safety factor in this region.
   / I don't want to drill my Loader mount bracket.... does it actually matter? #20
If you are talking about the bolts that mount the diverter to the arm, they dont go to the outside of the arm. I drilled and tapped just one side of the tubular arm
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: 91,121 Plate: Body Type: 4 (A55853)
Year: 2014 Make...
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
Portable Restroom (A54865)
Portable Restroom...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2019 Ford F-150...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
