Does anybody build custom trailers anymore?
   / Does anybody build custom trailers anymore?
Snowmobile trailers are to wide and I do not want a deck over design. I want something like the old Snowco tandem axle job, just wide enough on the deck for a golf cart and long enough for 2 of those nose to tail. That will give me the width I want and the length for our two tractors to go to shows and plow days.
   / Does anybody build custom trailers anymore? #12
Around here, welding shops will build any kind of trailer you want.
SR
   / Does anybody build custom trailers anymore? #13
1699005049756-jpeg.830110
What is that, a booster seat?
   / Does anybody build custom trailers anymore? #14
How far are you willing to travel to get one?
Or a better question, where are you located?
Maybe add it to your profile?
There is a custom builder 18 miles from me but if you live beside the Hinomoto Tractor factory in japan I can't help you. :)
   / Does anybody build custom trailers anymore? #15
If you want to go "custom", then write up the specs you want.
  • Length x Width of bed
  • Weight Capacity
  • Frame material (steel/aluminum)
  • Bed material (2x6 or 2x8 or 2x12, plywood, metal, expanded metal, etc)
  • Bed Design (flatbed, open tracks, side rails, etc).
  • Tires and Wheels. Tandem, Dually, Triple, etc
  • Ramp Design. Or alternatively drop flat to ground for loading.
  • Tie Down Points and types
  • Etc.
Then start contacting shops.
Even if you have to drive from Indiana to Texas to pick up the trailer, that would be a 1 or 2 day drive, and wouldn't be the end of the world,.
Also consider how your needs will evolve over time. So, make it to exactly fit your two tractors, and then you have problems if you buy a bigger tractor.
I love my little 4x8 Haulin flatbed. But, it is small for most of my needs. So, now I have a flatbed utility trailer that is 8'6" wide. What a pain to tow. But, it does most of what I need, except for hauling equipment heavier than about 8,000 lbs.
   / Does anybody build custom trailers anymore? #16
Felling trailers in Sauk Centre Minnesota used to build customs. Not sure if they still do or not. They might have moved on to the big stuff now.
I see Felling trailers all over the place up here. They have a good rep!
I live in Kokomo, Indiana which is about an hour north of Indianapolis.
   / Does anybody build custom trailers anymore? #19
Look at BNM Trailer Sales in Elsie, Michigan, east of St Johns, Mi. I have 2 of their standard trailers, but the second on was customized for my needs. Taller sides, heavier axles, special paint job, etc. Contact Us | BNM Trailers Sales, Inc.
Jon
   / Does anybody build custom trailers anymore? #20
Another thought is finding an appropriate size boat trailer and adding a deck.
There are lots of long skinny boat trailers around.
Finding a used one would be a lot cheaper than a custom build, but would require some fabrication work.
As a bonus you may be able to score something galvanized
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2012 Audi Q7 (A50324)
Schuler 220 BF Feed Wagon (A50514)
Schuler 220 BF...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
