Hydraulic Top Link Hose Lengths
/ Hydraulic Top Link Hose Lengths #1
Supraman0614
Western, NY
LS XR4145, Jacobsen Turfcat
I bought a cylinder for a hydraulic top link, and I need to make some hoses. So as not to reinvent the wheel, I was curious if anyone with a hydraulic top link could share their hose specs (lengths/fittings/what they would do differently next time, etc.). Thanks!
/ Hydraulic Top Link Hose Lengths #4
Yep, same sizes I used for mine.
Thanks for the info and input!
/ Hydraulic Top Link Hose Lengths #6
Pre-made 3' hoses were cheaper for me than getting custom length
Get out a tape measure and see what works on your set up
/ Hydraulic Top Link Hose Lengths #7
A 24" & 30" hose should work well for your LS XR4145.
Use 90* adaptor fittings at the cylinder ports.
Would you guys mind posting a pic of your setups with those lengths?
I'm not happy with the 2 x 36" hoses on my MT240 setup, I'd like to do something different.
Also, are BSP fittings common to hydraulic shops, or places like NAPA where you get hoses made, or should I find some BSP to NTP adapters and be done with it once are for all?
Edit* Found the (m)BSP to (m)NPT adapters the top link came with, so I can go all NTP with the new lines.
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
Giyi GY-CYHC Mini Quick Attach Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
Pair of Red Cedar Wood Rocking Chairs (A59231)
Pair of Red Cedar...
