Would you use this pic in an advertisement?
/ Would you use this pic in an advertisement? #1
square1
Michigan
Ford 1700 4x4 w/ FEL
Would you buy this based on this pic?
/ Would you use this pic in an advertisement? #2
I would probably also consider the price and reviews, if any.
/ Would you use this pic in an advertisement? #4
Depending on price.
I'm not sure I'd store a chain on that hook, let alone hook something to, or pull something by a chain attached to that hook.
/ Would you use this pic in an advertisement? #6
Not a welder... What is it about that hook (other than the company) that's not good?
I got my hooks several years ago from Ken's Bolt On Hooks, and they are top quality. I highly recommend them.
/ Would you use this pic in an advertisement? #7
Inconsistent bead size, substantial crater at the lower end of the weld, insufficient throat depth also at bottom. Will it break, maybe not, would I put my name on it...nope.
/ Would you use this pic in an advertisement? #10
So it got galvanized after the weld?
It does look like he ran out of stick or stopped the weld right there for some reason, wouldn’t have used that side but it’s not like the average photographer would figure that out.
/ Would you use this pic in an advertisement? #13
Did you
View attachment 829123[
It depends on what you'll be asking of it. Probably 90% of the tractors here would stall or deform the bucket before that thing would fail.
Not nearly as pretty as Ken's BOH, you only need 2, what's the holdup? 👍
/ Would you use this pic in an advertisement? #16
How much were you expecting from Titan?
/ Would you use this pic in an advertisement? #17
I find it hard to believe that your little tractor will break it. If so, it might be better to break the hook than your tractor. Why don't you buy it and if it breaks, post pictures.
/ Would you use this pic in an advertisement? #19
The sheet metal you attach ANY of the afore mentioned hooks to will deform long before the weld fails anyway. I roll my own anyway, no need to buy them. Shield gas MIG welding is never 100% aesthetic unless it's pulsed MIG. JMO.
/ Would you use this pic in an advertisement? #20
I have the Amazon version of those. The 3/8" refers to the size of the chain, not the bolts. The bolts that came with mine are 1/2". Mine would probably pull through the bucket material before failing. They will also outwork the lift on my Kenbota. :rolleyes:
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2021 CATERPILLAR 303.5E2CR EXCAVATOR (A62129)
2021 CATERPILLAR...
Bell 1600 Gallon Nurse Trailer (A63118)
Bell 1600 Gallon...
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
