Tractor backhoe - homemade
/ Tractor backhoe - homemade #1,583
Yep, This is what I get now on pictures that were there Saturday:
The pictures are in Sundays post:
I'm not sure why that happened, those are all my pictures, there is no copyright...
Anyway, I continued working so I made my seat turnable. Belarus has its batteries behind the drivers seat so I had to move them down under the cab. Here are the results. Now I can continue working on joystick mounts etc
/ Tractor backhoe - homemade #1,587
Wow, that little pto extension shaft came in handy. Got me wondering if i might ‘need’ one too. You know, just in case 😂
/ Tractor backhoe - homemade #1,588
Could not manage to lift the machine enough with a small forklift for coupling so I decided to fix the pump in place and use a shaft to turn it from a distance. Stabilizers did the work easily 😁
I assume you know you have to slowly move cylinders back and forth to get oil in them, and not press it with full force against the end stroke untill all air is out ?
We once had to repack the cylinders of a brand new wheel loader because the new guy forced the air along the dry piston seals, creating compression temperatures like a diesel engine, burning the seals out 🙈
Thanks for advice Renze, I was aware of that. Previous bad experiences 😁.
Vigo, it could not be done without it, that pump couples direct on to pto shaft
/ Tractor backhoe - homemade #1,591
What is the the most common mini excavator quick disconnect bucket and attachment type there? Is it more universal there? Here there are over a dozens different types and even vary with the same manufacturer.
Modified the Kubota M59 to Kubota miniEx (8-20K #machines) quick attach. Makes changing buckets and attachments so easy. Appreciate the simple yet strong design. New and used attachments are plentiful and often less expensive. Can’t wait to see what innovations you make.
/ Tractor backhoe - homemade #1,592
Holy crap that thing looks awesome on the tractor.
I am still itching to build the 'middle arm' for my tiny backhoe. I did buy a cylinder for the project.. and that's as far as that's gotten, lol.
Can't wait to see the bucket build!
Well, there are many types, probably 20-30 different ones.
Thanks Vigo. 😊
/ Tractor backhoe - homemade #1,594
What is the the most common mini excavator quick disconnect bucket and attachment type there? Is it more universal there? .
Here in Holland we predominantly have Verachtert CW system, in different sizes. Cat bought the company, it serves the home market under its old name and worldwide markets as Cat Worktools. Traditional pin grabber couplings like you have in the States are next to nonexistent, though the Scandinavian standard, with tiltrotator setup, is taking on fast.
Yes but pin grabbers are the fastest tool changing couplers. You only need additional hydraulic line to lock it
/ Tractor backhoe - homemade #1,596
CW system too, but its built more compact, with less loss of breakout force.
Its an earthmoving oriented system: With heavy shears and crushers in demolition works, (lifting rather than pushing) it is loaded the wrong way, and sometimes the wedge cam breaks off the bucket due to fatigue. Solving this would mean altering the standard, which is not going to happen...
Thats why in demolition, OilQuick is gaining popularity, though it will never fully replace the CW standard in Holland: CW standard is more than 45 years old, older than any other standard.
I've welded my front pin on the bucket, and rear one gets inserted all the way through the bucket and coupler. This way even if my front hook snaps rear pin will hold the bucket
/ Tractor backhoe - homemade #1,598
You finished it just in time for your Christmas present! Merry Christmas!
Are there no used cheap buckets over there you can do a weld job on? I see them here at different auctions.
Even if there are I'm going for the 4 in 1 bucket 😁
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
