Tractor backhoe - homemade
/ Tractor backhoe - homemade
Homemade 10 minutes hydraulic pipe bender; does not look pretty but it works great.
So I made all those metal pipes...
...and started mounting flexible ones...
/ Tractor backhoe - homemade #1,563
Looking good! Hard lines really gives a nice touch on these projects.
So I started at the bucket cylinder, added auxilary command (for rotator, jaw bucket, misc), it will be controled through emv witha a push of a button...
After that came the tricky part, kingpost "hosing" where all those lines + rotation, kingpost brakes and electric lines come together...there's the real party 😁. Will post in few days...
Finished connecting left hydraulic distributor valve, moving on to the right.
By the way I'm checking every function with compressed air so I get those hoses in the best configuration and not messed up
/ Tractor backhoe - homemade #1,567
First boom, upper and lower hoses connected. Also, lift cylinder done. There I installed hydraulic block valve for safety. Even in case my hoses break, this keeps the cylinder in place and prevents any boom movement
/ Tractor backhoe - homemade #1,570
Amazing craftsmanship! Enjoy your sharing of your build.
Excuse my ignorance but have trouble seeing the safety block valves. Could you show that in a little more detail?
Yes, so here are the details.
Really? It shows all the pictures when I open the page. 🤔
/ Tractor backhoe - homemade #1,577
Working now
/ Tractor backhoe - homemade #1,579
Ok so here are those pictures again.
Thank you for the additional pictures and details on block valves. Be safe on Think more safety devises should be used and maybe retrofitted on older equipment. Any down side other than initially using it to cost?
Your skill set is definitely inspiring.
No problem. Those valves are not expensive, you can retrofit any cylinder. They cost 34 $ a piece. Simply adjust the lenght of those metal hoses and it works.
2015 Freightliner (A64119)
2015 Freightliner...
Rooster (A64557)
Rooster (A64557)
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
