72" Rear blade with offset and hydraulic angle option
/ 72" Rear blade with offset and hydraulic angle option #1
Templecruiser
New Hampshire
Kioti cab CX2510
I bought a new cab Kioti cx2510 with snowblower. I would like to get a rear blade to help with the small snow amounts. The Cx come stock with a rear remote, so would like to use it, especially having a cab. Would like offset with pin, not bolts. 84" I feel is to big, so 72" is what I'm looking for. Loved the EA one, but 4 month wait for a rear blade is rediculas. So any other option out there. The only other I found was the landpride rb1672, but with hydraulic you have to unbolt everything if you want to push with the blade. Would like to keep it $2500 or less as it would only be used for snow, but I want a quality one also.
/ 72" Rear blade with offset and hydraulic angle option #2
You know what they say, you can have any two, good, cheap or fast. But you won't get all 3.
Good luck in your search. ;)
You saying you can't buy a quality rear blade with hydraulic for less then $2500? EA was less then $2500 and they look very well built. But can't wait 4 months for it.
/ 72" Rear blade with offset and hydraulic angle option #4
Have u tried shopping for a used one ?
/ 72" Rear blade with offset and hydraulic angle option #6
Remember - when you use a rear blade it, most often, will be angled. An angled 72" rear blade will cut somewhere around a 55" to 60" path.
I have a HD Rhino rear blade. It's 96". When angled to blade snow it cuts a 76" path.
/ 72" Rear blade with offset and hydraulic angle option #7
His listed tractor is a Kioti CX2510, that 60 angled inches will cover his track just fine.
Bite the wait time for the EA; it'll likely arrive early anyhow.
/ 72" Rear blade with offset and hydraulic angle option #8
Anything with hydraulic angle is gonna need the cylinders unbolted or unpinned to spin the blade 180 degrees to push with it.
Having offset that adjusts with just a pin usually pushes you to a higher end and heavier blade (also more money.
Something like the landpride RB37 series..
/ 72" Rear blade with offset and hydraulic angle option #9
No, you can't get it fast. One of the 3.
Again, good luck in your search. (y)
Pulling pin on hydraulic isn't a big deal, but on the landpride rb1672 you need to unbolt the whole metal piece the piston attaches to just to spin the blade. Not a very good set up. More of a after thought. Woods make a 72" with hydraulic, but bolt offset. Then I find ones with pin offset, yet no hydraulic option. EA seems to have the only one set up with pin offset with hydraulic, I would just need to wait until February to get, then winter is about over.
/ 72" Rear blade with offset and hydraulic angle option #12
Bought the EA. Just what I need, but I will wait. Ill just buy a cheap one to use this winter until it comes in.
Thanks so much for the business and understanding our lead time. I assure you that it'll be the best investment.
For others looking, here's our scrape blade page.
There's always something fun goin on in the EA Channel Group.
Aaaaand a little vid I made about our compact blade with hydraulic options!
All are painted black, now.
Travis
/ 72" Rear blade with offset and hydraulic angle option #13
Wow, I forgot about this video I made, which features our HD blade and Compact blade, both with hydraulic features!
Travis
Travis
You should mention on your website lead times for products. People will be surprised when they pay for item, then get a email later that says it will be 4 months before you get it.
2018 ADDCO ROAD SIGN DH1000-ALS (A60736)
2018 ADDCO ROAD...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
(INOP) 1981 CATERPILLAR 950 WHEEL LOADER (A59823)
(INOP) 1981...
