72" Rear blade with offset and hydraulic angle option
   / 72" Rear blade with offset and hydraulic angle option #1
Templecruiser
New Hampshire
Kioti cab CX2510
I bought a new cab Kioti cx2510 with snowblower. I would like to get a rear blade to help with the small snow amounts. The Cx come stock with a rear remote, so would like to use it, especially having a cab. Would like offset with pin, not bolts. 84" I feel is to big, so 72" is what I'm looking for. Loved the EA one, but 4 month wait for a rear blade is rediculas. So any other option out there. The only other I found was the landpride rb1672, but with hydraulic you have to unbolt everything if you want to push with the blade. Would like to keep it $2500 or less as it would only be used for snow, but I want a quality one also.
   / 72" Rear blade with offset and hydraulic angle option #2
You know what they say, you can have any two, good, cheap or fast. But you won't get all 3.
Good luck in your search. ;)
You saying you can't buy a quality rear blade with hydraulic for less then $2500? EA was less then $2500 and they look very well built. But can't wait 4 months for it.
   / 72" Rear blade with offset and hydraulic angle option #4
Have u tried shopping for a used one ?
   / 72" Rear blade with offset and hydraulic angle option #6
Remember - when you use a rear blade it, most often, will be angled. An angled 72" rear blade will cut somewhere around a 55" to 60" path.
I have a HD Rhino rear blade. It's 96". When angled to blade snow it cuts a 76" path.
   / 72" Rear blade with offset and hydraulic angle option #7
His listed tractor is a Kioti CX2510, that 60 angled inches will cover his track just fine.
Bite the wait time for the EA; it'll likely arrive early anyhow.
   / 72" Rear blade with offset and hydraulic angle option #8
Anything with hydraulic angle is gonna need the cylinders unbolted or unpinned to spin the blade 180 degrees to push with it.
Having offset that adjusts with just a pin usually pushes you to a higher end and heavier blade (also more money.
Something like the landpride RB37 series..
   / 72" Rear blade with offset and hydraulic angle option #9
No, you can't get it fast. One of the 3.
Again, good luck in your search. (y)
Pulling pin on hydraulic isn't a big deal, but on the landpride rb1672 you need to unbolt the whole metal piece the piston attaches to just to spin the blade. Not a very good set up. More of a after thought. Woods make a 72" with hydraulic, but bolt offset. Then I find ones with pin offset, yet no hydraulic option. EA seems to have the only one set up with pin offset with hydraulic, I would just need to wait until February to get, then winter is about over.
Electric Mobility Scooter (A54815)
Electric Mobility...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
Galvanized steel Fence (A53424)
Galvanized steel...
2019 VOLVO EC220EL EXCAVATOR (A52706)
2019 VOLVO EC220EL...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2022 AGT Top Cat Skid Steer Side Arm Mower (A54865)
2022 AGT Top Cat...
