RK55 overheating
/ RK55 overheating #1
SMiller13
RK55
Hi All,
We have been doing some bush-hogging. The fields had a lot of straw like plants and they put out a lot of dust and pieces of plant.
The RK55 overheated. Checked the radiator and found the screen filters were clogged. Cooled it down, drove over to the hose and cleaned off the filters. There does appear to be any obstructions to airflow but the overheating continues. The tractor will run about 20 minutes or so before the overheat light comes on.
Anyone had this problem? Ideas?
/ RK55 overheating #2
Coolant level? Is the radiator REALLY clean? Do you have a radiator genie?
/ RK55 overheating #4
The fan on these units draw a ton of air thru the rads normally. I found when I mow the rad gets stuffed with bugs, debris very quickly. There is a condenser for my AC in front of the radiator ,and behind that is very hard to clean out properly. I end up using my gas blower and a garden hose to clean mine out after I mow for the day everytime.
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A62131)
UNUSED WOLVERINE...
2019 FORD F-250 4X2 PICK UP TRUCK (A59908)
2019 FORD F-250...
CATERPILLAR 236D SKID STEER (A62129)
CATERPILLAR 236D...
RoadTec RP190 (A63118)
UNUSED JCT HYD TRENCHER (A62131)
UNUSED JCT HYD...
