PTO generator
/ PTO generator #1
Swblack1216
Washington state
Kioti ck25, Ford 4500
I picked up a beast PTO generator bigger than I can run with my coyote CK 25, but I’ll get what I can out of it. My question is I need a new meter one I can see digital preferred voltage frequency and current draw. Any suggestions would be appreciated TIA.
/ PTO generator #6
I have a 25 kW almost identical to that. I made my trailer for mine so that I can get my welder on it.
/ PTO generator #7
Maple leaf, that's a nice unit, where did you find that meter, do you have a link?
Thanks
/ PTO generator #8
I see one meter on the generator, is that a hz meter?
Once you get her to spinning I find hz to be the more important measurement.
The voltage may have some adjustment but the hz are fixed to the rpm of your pto.
If the load is pulling your tractors engine down the automatic voltage regulation will try and keep the voltage up,
but you will see the hz slowing down.
I use the hz meter on the generator to set my tractor rpm when starting the generator up.
/ PTO generator #9
This.
Depending on what you're powering with the generator, some things do NOT tolerate the Hz being "off". If your tractor engine is getting lugged down, your frequency is being thrown off.
/ PTO generator #10
That meter is a volt meter. It's a fairly inaccurate, cheap meter. I verified mine with a DMM and do so everytime I use it. I need to mount one of those multifunction readouts on mine. As others said, frequency is key. It's one of the factors that have to be synchronized when tying a generator to the grid. The other is voltage. Since these gens don't tie to the grid those measurements can fluctuate quite a lot. I install and commission voltage regulators on large generators. This involves tuning the regulator to grid conditions. These PTO gens are like a black start in a power plant. They are their own little grid being controlled by that generator. Do that with caution. Most of all, make sure you are isolated from the grid at all times.
/ PTO generator #11
Yes it is a tad bit easier to just get the generator up to speed for the proper hz, closing a breaker and powering up a system, then having to bring the generators frequency to just a tiny bit faster then the tie in power, the voltage to be equal or a tad bit higher and watching the sync scope for the needle to just slowly rotate to the 12 o'clock position and in sync and closing the tie breaker, then bring the voltage up to feed out at the desired amperage. Or to keep increasing the output untill the original primary can be taken off line and the new source becomes the primary and only source.
/ PTO generator #12
Lou, it's been a while since you've seen that done I think. That as the way you and I learned how to do it. All of that is automatic now with auto synchronizers and sync check relays. The hydro I finished up commissioning yesterday is a no touch. Hit the start button and it goes online. Technology is dumbing down the workforce. Believe it or not, operators that know how to manually sync a unit are scarce these days.
/ PTO generator #13
It has been a day or two :D
Back then depending on the facility it could be a lot of fun doing the calibrations and inter connects. Especially a black start plant with a diesel or natural gas piston (800 rpm) startup unit, or even just a bunch of slow speed units getting paralleled to run a plant, then through in a steam turbine or even a gas turbine into the mix.
Thinking back it's been close to 20 years ago the last time I had to parallel a generator or sync between two with number three in a hot standby, or the co-gens tied into utility power.
/ PTO generator #14
Brings back good memories, last time I had to sync with the grid was early 90's. After all the new automation with sychronizers, I wasn't needed for that task anymore.
The automation does a safer and quicker job of it also.
/ PTO generator #16
You'll be surprised. I'm guessing your tractor will run your whole house easily. I know the generator will. I ran mine on my old 5310 and it never really knew it was there.
/ PTO generator #17
I'm going to start a black site up on Monday of next week. I look back at the things I've seen and experienced in the power business and it actually amazes me. I work for a company that makes turbine/governor controls, voltage regulators for excitation, boiler controls, BOP, BMS and the DCS that ties everything together and provides a computerized operator interface. I have to be knowledgeable on every part of it. And I'm getting to old to want to keep up anymore. I'm planning on maybe another year if someone doesn't piss me off sooner.
/ PTO generator #18
I feel for you there. With all the technology and the push in the 80's and 90's for multi-skilled employees, then having new managers that didn't have enough knowledge of system operation or theory making the decisions. I got one of those fed up moments after someone else messed with a project I was on and I gave that effective immediately termination notice.
We are losing a lot of learned over time skillsets in the workforce, that can't be replaced on a moments notice.
Hang in there as long as you can! I wish you well.
/ PTO generator
Thanks going to do a lockout on my panel it will be isolated. I will check it with my Fluke.
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A61165)
2005 International...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 48in...
1979 HEIL TRANSPORT TRAILER (A60736)
1979 HEIL...
500BBL WHEELED...
2016 Isuzu NRR 18ft. Flatbed Truck (A61568)
2016 Isuzu NRR...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
