Loader bucket won't fully curl up
/ Loader bucket won't fully curl up #1
Horseman1$
JD 5085E / H240 loader
Have JD 5085E with a H 240 loader. While doing dirt work the bucket is extended and will retract about 4 inches and freeze up. Was working fine and I heard a pop. There are no leaks anywhere.
/ Loader bucket won't fully curl up #2
Sounds like the classic issue of a quick connect popping out. I suggest that you check all of the quick connects, pull them out and reseat them to make sure. But first, with the engine off, move the joystick in all directions to release any pressure.
/ Loader bucket won't fully curl up #3
What was you doing when it happened ?
/ Loader bucket won't fully curl up #4
What kind of dirt work? Back dragging with bucket fully extended/dumped? Bent a rod and will only retract til the bent part binds in the gland?
/ Loader bucket won't fully curl up #5
Or possibly popped the piston off of the rod.
/ Loader bucket won't fully curl up #7
Im thinking it wouldnt even try retracting the 4" if that were the case
You're probably right but I was thinking if the nut fell off 4" might be about the distance the rod could travel through the piston before it quit blocking the hole and let fluid bypass. That would likely only happen once as the rod probably wouldn't line up with the hole to go back in the piston.
/ Loader bucket won't fully curl up #8
If you cannot backdrag with a loader it is worthless .
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
JOHN DEERE 8 SHANK CHISEL PLOW (A63291)
JOHN DEERE 8 SHANK...
H&H 500 GALLON T/A SPRAYER (A63291)
H&H 500 GALLON T/A...
