Loader bucket won't fully curl up
   / Loader bucket won't fully curl up #1
Horseman1$
JD 5085E / H240 loader
Have JD 5085E with a H 240 loader. While doing dirt work the bucket is extended and will retract about 4 inches and freeze up. Was working fine and I heard a pop. There are no leaks anywhere.
   / Loader bucket won't fully curl up #2
Sounds like the classic issue of a quick connect popping out. I suggest that you check all of the quick connects, pull them out and reseat them to make sure. But first, with the engine off, move the joystick in all directions to release any pressure.
   / Loader bucket won't fully curl up #3
What was you doing when it happened ?
   / Loader bucket won't fully curl up #4
What kind of dirt work? Back dragging with bucket fully extended/dumped? Bent a rod and will only retract til the bent part binds in the gland?
   / Loader bucket won't fully curl up #5
Or possibly popped the piston off of the rod.
   / Loader bucket won't fully curl up #6
   / Loader bucket won't fully curl up #7
Im thinking it wouldnt even try retracting the 4" if that were the case
You're probably right but I was thinking if the nut fell off 4" might be about the distance the rod could travel through the piston before it quit blocking the hole and let fluid bypass. That would likely only happen once as the rod probably wouldn't line up with the hole to go back in the piston.
   / Loader bucket won't fully curl up #8
If you cannot backdrag with a loader it is worthless .
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2015 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A50323)
2015 Chevrolet...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
