Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600)
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #1
rmonio
New Market, MN
JD 4600, JD B
I have a JD4600 and I’m wondering if anyone has done this or not. Is there a kit to replace the ROPS lights and the headlights?
Thanks!
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #2
I bought a set of LED lights to mount on the ROPS bar, but they are still sitting in the box! I know this doesn't help, but at least there's someone else that has started on this. These lights have been sitting for about 5 years. It's easy to order stuff, but then more difficult to make the time to act on it.
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #3
I can't speak to your situation but when I bought my 1066, it had (non working) lights on the fender and some wimpy lights up front.
I replaced the entire wiring harness and at same time, replaced all lights with LED's.
It was an "OMG" difference when all are turned on. It really illuminates the field.
If you can get what fits, I think it's a no-brainer.
To replace the lights, do you need a different power configuration? Or can I just wire the new bulbs and plug them into the old wiring?
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #5
Yes, I used original wiring as the LED takes way less power than halogen. 2 on the ROPS facing forward and back on each side for a total of 4 and it is plenty bright on mine. Never use the headlights in the hood. Originally I wanted a light bar on the front of the canopy also but decided that would be overkill. I love LED flood lights.
Ah. That’s great news. I have two on the ROPS facing forward and will replace those first. I’ll have to see if the headlights on the 4600 can be replaced with LEDs, too. Anyone know where I can get those?
@fidowanttobe, what headlights did you get for you ROPS?
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #7
Expect you can. I did on my 4300 and likely the same.
Remove a bulb and get the number, then pick up LED bulbs that cross reference to that number.
This is it.
Hmm. Ok. I’ll check with my JD dealer and see what can be done on cross-referencing a bulb to a LED version. They should know.
Update: I ordered the bulbs and will put them into the ROPS lights that I have.
Question - why didn’t you put them also in the headlights on the tractor?
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #10
To whom is the question?
You. I read your message that you didn’t change the headlights.. rather, only the ROPS-mounted lights.
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #12
Am pretty sure I changed out the headlights with LED's.
Ok. I plan to do the same. Having the extra light in the winter will be a big win - that it won’t drag down the battery if I leave them on without the engine running.
Unfortunately the bulbs do not work. My lights in my ROPS are halogens.
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #15
I used LED bar lights to replace the halogens, far superior lighting
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #16
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #17
/ Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #18
I did this for my headlights. the oem 1s were rather dull. I found Tractor supply carried led lights and mounted them in place of the original headlights. and then to be extra sure I added a 2nd pair facing forward on the rollback as well. its like daylight when they are on.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2013 Freightliner Forest River 390BH 39ft. Class A Motorhome (A59231)
2013 Freightliner...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A59230)
2017 GMC Sierra...
2016 KENWORTH W900 DAY CAB (A59905)
2016 KENWORTH W900...
