Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600)
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600)
You. I read your message that you didn’t change the headlights.. rather, only the ROPS-mounted lights.
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #12
Am pretty sure I changed out the headlights with LED's.
Ok. I plan to do the same. Having the extra light in the winter will be a big win - that it won’t drag down the battery if I leave them on without the engine running.
Unfortunately the bulbs do not work. My lights in my ROPS are halogens.
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #15
I used LED bar lights to replace the halogens, far superior lighting
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #16
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #17
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #18
I did this for my headlights. the oem 1s were rather dull. I found Tractor supply carried led lights and mounted them in place of the original headlights. and then to be extra sure I added a 2nd pair facing forward on the rollback as well. its like daylight when they are on.
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
