Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600)
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
I have a JD4600 and I’m wondering if anyone has done this or not. Is there a kit to replace the ROPS lights and the headlights?
Thanks!
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #2
I bought a set of LED lights to mount on the ROPS bar, but they are still sitting in the box! I know this doesn't help, but at least there's someone else that has started on this. These lights have been sitting for about 5 years. It's easy to order stuff, but then more difficult to make the time to act on it.
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #3
I can't speak to your situation but when I bought my 1066, it had (non working) lights on the fender and some wimpy lights up front.
I replaced the entire wiring harness and at same time, replaced all lights with LED's.
It was an "OMG" difference when all are turned on. It really illuminates the field.
If you can get what fits, I think it's a no-brainer.
To replace the lights, do you need a different power configuration? Or can I just wire the new bulbs and plug them into the old wiring?
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #5
Yes, I used original wiring as the LED takes way less power than halogen. 2 on the ROPS facing forward and back on each side for a total of 4 and it is plenty bright on mine. Never use the headlights in the hood. Originally I wanted a light bar on the front of the canopy also but decided that would be overkill. I love LED flood lights.
Ah. That’s great news. I have two on the ROPS facing forward and will replace those first. I’ll have to see if the headlights on the 4600 can be replaced with LEDs, too. Anyone know where I can get those?
@fidowanttobe, what headlights did you get for you ROPS?
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #7
Expect you can. I did on my 4300 and likely the same.
Remove a bulb and get the number, then pick up LED bulbs that cross reference to that number.
This is it.
Hmm. Ok. I’ll check with my JD dealer and see what can be done on cross-referencing a bulb to a LED version. They should know.
Update: I ordered the bulbs and will put them into the ROPS lights that I have.
Question - why didn’t you put them also in the headlights on the tractor?
   / Replacing Halogen headlights (built-in, ROPS mounted) with LEDs? (JD 4600) #10
To whom is the question?
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
