What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,441
Sometimes having a smaller tractor around is a blessing. I need to dig a small shallow trench ~250 to bury some low volt wire. My tractor and backhoe is a bit big, and due to its size, wont fit in a portion of the area needed. I get to hand dig. Nice duo!
The pain of using a shovel when you've got a backhoe nearby; that must have been a real kick. 🤣
   / What did you do on or to your LS Tractor today? #2,442
I rented this "ground saw" for maybe $150 from home depot, it cuts a 2" wide trench anywhere from 0-13 inches deep. It did 150 feet at max depth in about 10 minutes, it was amazing.
   / What did you do on or to your LS Tractor today? #2,443
ooooOOOOOooooooo....... :eek:
I might be heading to Home Depot this weekend! Thanks for the tip!
   / What did you do on or to your LS Tractor today? #2,444
So what I've been using mine for mostly this summer is grading the gravel road with the land plane, and watering young trees. We've gone into a bad drought over the last 6 weeks and some young and expensive trees I planted were struggling. A water hose won't reach easily, so what I do is I fill the bucket on the tractor up about 2/3rds with water, then I drive up to the trees and gently dump water on them. If I'm careful I can water several trees thoroughly without leaving the seat. Works great.
There's a million uses for a compact tractor.
   / What did you do on or to your LS Tractor today? #2,445
Then again, on my first digging experience with it, I kinda wished it was bigger. It took me over an hour and several re-positionings to get those two little stumps out. It's very easy to pull the whole machine toward the hoe, even with it fully off its wheels, supported by the stabilizers and the bucket. On my last repositioning, I had an idea; I turned a third stump into a traitor against its brethren. Doing this kept the machine from getting pulled toward the work:
   / What did you do on or to your LS Tractor today? #2,446
Ahhhh, read your owners manual ---- it SPECIFICALLY states to NOT lift the tractor / wheels off the ground when digging. Definitely puts stress in parts that are not supposed to be stressed to that point.
Plus, setting the parking brake, with 4wd engaged, and the tires on the ground, will put more resistance to pulling yourself backwards.
Another easy modification you can do is to bolt "feet" onto the stabilizer pads. Simple 2"+ angle iron bolted perpendicular to the "dig", will amaze you! Really, really, helps keeping the tractor in place.
Here is a link to a discussion on here about them.
   / What did you do on or to your LS Tractor today? #2,447
That is a use that never occurred to me! nice!
   / What did you do on or to your LS Tractor today? #2,448
Perish the thought! :LOL:
Since this is a frame (rather than 3-point) mounted hoe, I would not have expected that. Some years ago, I had a landscaper with a comparable sized (but much older) Kubota backhoe and he consistently lifted it off the wheels to dig.
Ooh! I like the angle-iron or U-channel idea! I think we even have some angle-iron laying around.
Thanks!
   / What did you do on or to your LS Tractor today? #2,449
Thanks!
Just because a "pro" does something does not make it right... Now a dedicated TLB is built a lot heavier than a CUT.
   / What did you do on or to your LS Tractor today? #2,450
A couple of those Bro Tech rippers you would have a down payment
for a new tractor
willy
2014 Ford Escape (A50323)
2014 Ford Escape...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
