/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,041
box blade to rough it up then grader blade to crown and smooth it, then rolled with 550lb roller.
Right on with the rolleršŸ‘ I wish our road had a roller to pack down after raking.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,042
3 Point Float Lock
On my old GC2300, I used a small bunji to keep my 3pt in full float. I added this 3 point float lock on my new GC 1725. Simple but effective.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,043
It isn't so much the cost of the parts as it is the cost of shipping. Even if I bought extras I'd still be paying more for shipping than the parts. I'll just wait until I have more stuff I need to get. The sheer pin is working well and I doubt I need to worry about loosing it. Who knows, I may just opt to replace them all with shear pins.
I just use quick pins in all of mine. Haven't lost one yet and it makes taking the deck off a bit quicker.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,046
you got the older non-drive over deck?
only reason I could think of pins need to be removed on axles to remove deck.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,047
I've got the same older deck -- I remover the rear wheels/axles and put in a solid axle with small wheels so I can stand it up (on edge) for winter storage. I agree those spring-type clips are awkward to remove -- I did lose one once, don't know how it got knocked off, but I found it, fortunately. Maybe I should try those pins....
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,048
Yeh, I do the same thing. Actually, I might have even gotten the idea from you from some older post of yours.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,049
You wouldn't have a picture of your set up would you?
Bobcat 763 (A60462)
Bobcat 763 (A60462)
MMS MS750 Remote Control Lawn Mower (A60463)
MMS MS750 Remote...
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 MACK GU713 CAB AND CHASSIS (A60736)
2013 MACK GU713...
Bobcat S740 (A57148)
