MT573cps hydraulic whining question
/ MT573cps hydraulic whining question #1
Mud2Money
Michigans thumb.
LS MT573CPS, NH TC45DA , Case SC
So question for those of you with mt5’s. Does your tractor have hydraulic wining and does it go away or consistent ? It never bothered me much. I know some units do groan from relief valves etc.
I recently got a NH hydrostatic tractor. Only groan is from the drive and it doesn’t slow when I lift the loader etc.
I know gpm numbers are largely inflated. But that’s one thing that does get me is the tractor physically slows when I lift the bucket or curl etc while driving. Yes the Rpms are over 2200 usually. Almost makes me wonder if I have a plugged screen or something. 275 hours , filters have been done.
/ MT573cps hydraulic whining question #2
A slow speed sharp turn will get my MT 573 to whine, but whine goes away as wheels straighten.
Mine does not slow down while lifting or adjusting the bucket to curl. Hope that helps.
Are you using the throttle or pedal?
I also own a NH TC40-D and its been a great tractor. Good luck.
I usually use the stationary throttle. Mine slows down and I can hear it in the rpm a little when I’m cruising along and use the hydraulics. I just recently got the Tc45da but it’s been great. It’s super steer so I have been using it as my fork lift and for brush cutting tight areas.
/ MT573cps hydraulic whining question #4
Mine whines when turning also.
It does not slow when working the loader and driving. I have been building up my driveway, so moving quite a few buckets of dirt.
My quick attach handle broke on one side today. I went to take the bucket off to put my forks on and the pin jammed on one side. The handle would not budge no matter what. I flooded it with penetrating oil...nothing.
Took the small hammer to it. Figured I would knock it loose...nope. Just broke the end of the shaft coming through the spring that joins up with the actual handle.
My qa handle gets sticky as well if I moved a lot of stone or dirt. It gets small rocks packed in. I blow it out with a air gun first then it usually pops free.
Well good news. Replaced the PSS/steering filter again at 275 hours. Back to normal. Guessing filter was getting restricted.
/ MT573cps hydraulic whining question #7
I will keep that in mind. I am coming up on my 50 hr change of all the filters.
BTW, here is where my QA handle broke off.
Yeah a friend used my tractor and beat it with a hammer once to unlock it. Bent the handle some but luckily did not break the pin. If the pin breaks I’ll be machining a new one. I am half tempted fabricate some stuff mimicking my NH. Those handles are stout and open easy plus they have a grease fitting.
/ MT573cps hydraulic whining question #9
On mine actually I think the hole for the pin that's in the bucket is slightly out. From day one that side was extra stiff when releasing. I figured it would loosen up with use like the other side did. Except it didn't.
Once I get the pin out of the bucket, I'm going to grind that edge back on the hole so the pin fits in a little looser. It wouldn't take much, maybe 3/32.
/ MT573cps hydraulic whining question #10
Thanks for PSS/filter change as a whine solution. Probably have that issue at some point. I use the TC-40 with forks,
6' shredder and box blade. Have other implements sized for it but those 3 are the ones I use 99% of the time. Also, take it into the woods to clear trails etc
TimberFarm, let us know how that 50hr filter change goes. A few of mine had to have been torqued on by a machine, then painted over with a heavy coat of black paint.
/ MT573cps hydraulic whining question #11
I was taking a look at the filters after reading how there were two #'s for one of the filters. I figured look under there and just copy the numbers off what I have...Nope. Like you said they are all painted black. The hydraulic filter looks like it is about a gallon size. I'm going to have to buy a strap wrench or something to get around that thing and hope and pray it isn't painted shut in place.
/ MT573cps hydraulic whining question #12
I had to hammer a long screw driver through the big hydraulic filter to get it off. All painted black and incredibly tight on there.
/ MT573cps hydraulic whining question #13
I try to do that as a last resort. I had a vehicle once where I had to do that and it still didn't come off. The screwdriver just ripped right through the metal all the way around.
/ MT573cps hydraulic whining question #14
I had to order a strap wrench from auto store to fit the hyd filter. It was a beast to get off. In fact I couldn't get it to break loose. My sons couldn't get it off either. Finally had a shop mechanic come out. Mechanic had to remove back right wheel, use my strap wrench and a 3' cheater bar to get that thing off. It got done but was a real pita.
I usually don't take pics of oil changes etc. However, after the hyd filter episode, I did take a few pics of the pss/hyd filters and found them looking through my phone today. Posting them here to maybe help others following where this thread is going.
/ MT573cps hydraulic whining question #15
Which filter is the second photo?
New filter looks like it would be pretty restrictive with a lot less holes in it than the old one.
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
2018 HINO 268 4X2 S/A 26FT BOX TRUCK (A69167)
2018 HINO 268 4X2...
2011 JET  48 FOOT SPREAD AXLE STEP DECK TRAILER (A67714)
2011 JET 48 FOOT...
25057SFL (A64557)
25057SFL (A64557)
PORTA POTTY (A68842)
