Is my hydraulic pump dead? (Tx1300F)
/ Is my hydraulic pump dead? (Tx1300F)
Going to check the seal on intake side again tomorrow.
And by the way now that i think about it., there is a small leak from the FEl hydraulic central. Is it possible that thats causing air to get mixed in the oil?. Would explain why it works for about 1 hour before it starts shuddering.
/ Is my hydraulic pump dead? (Tx1300F) #13
Thought maybe the filter was clogged so I drained the oil and took out the filter wich looked fine. Filled it back up and it was working for about one hour before it started shuddering/shaking again.
How much oil did you have to drain to remove and check the filter?
/ Is my hydraulic pump dead? (Tx1300F) #15
Basically all of it.
I have not changed mine, but isn't this it? If so, it is fairly high up and I would think not much fluid would need to be drained. My tractor is a Bolens G154 (Iseki TX2140) if there is a difference.
/ Is my hydraulic pump dead? (Tx1300F) #16
Thats not it, thats the high pressure side, suppling your 3 point linkage, check out the end of the larger diameter pipe, approx 20-25mm OD, below the leaver for either high and low or 4 wheel drive in your photo attached forwards and down.
/ Is my hydraulic pump dead? (Tx1300F) #17
I see my confusion now. The manual shows two filters. Both 18 and 27 as filters. 18 being the upper one and 27 the lower one. Are there both?
/ Is my hydraulic pump dead? (Tx1300F) #18
View attachment 819927 View attachment 819928
Your one is the lower on that page, filter 18 or 18a, I am going to guess possibly the other is for the hydrostatic tractor, my parts list covers both types of tractor, mine is iseki 2140,2160 plus hydrostatic,
/ Is my hydraulic pump dead? (Tx1300F) #19
Mine is gear but it appears to have a canister where filter 27 would fit into. I changed my fluid but did not check that, now I wish I had. My 3 point is fast so I don't think I have an issue, but it would be nice to know it is in good condition. I do not have a loader.
/ Is my hydraulic pump dead? (Tx1300F) #20
27 is what is on a 3 cylinder model. 18 is what is used on a 2 cylinder model. I haven't seen a parts book that covers both 2 & 3 cylinder models.
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
