Is my hydraulic pump dead? (Tx1300F)
   / Is my hydraulic pump dead? (Tx1300F)
Going to check the seal on intake side again tomorrow.
And by the way now that i think about it., there is a small leak from the FEl hydraulic central. Is it possible that thats causing air to get mixed in the oil?. Would explain why it works for about 1 hour before it starts shuddering.
   / Is my hydraulic pump dead? (Tx1300F) #13
Thought maybe the filter was clogged so I drained the oil and took out the filter wich looked fine. Filled it back up and it was working for about one hour before it started shuddering/shaking again.
How much oil did you have to drain to remove and check the filter?
   / Is my hydraulic pump dead? (Tx1300F) #15
Basically all of it.
I have not changed mine, but isn't this it? If so, it is fairly high up and I would think not much fluid would need to be drained. My tractor is a Bolens G154 (Iseki TX2140) if there is a difference.
   / Is my hydraulic pump dead? (Tx1300F) #16
Thats not it, thats the high pressure side, suppling your 3 point linkage, check out the end of the larger diameter pipe, approx 20-25mm OD, below the leaver for either high and low or 4 wheel drive in your photo attached forwards and down.
   / Is my hydraulic pump dead? (Tx1300F) #17
I see my confusion now. The manual shows two filters. Both 18 and 27 as filters. 18 being the upper one and 27 the lower one. Are there both?
   / Is my hydraulic pump dead? (Tx1300F) #18
View attachment 819927 View attachment 819928
Your one is the lower on that page, filter 18 or 18a, I am going to guess possibly the other is for the hydrostatic tractor, my parts list covers both types of tractor, mine is iseki 2140,2160 plus hydrostatic,
   / Is my hydraulic pump dead? (Tx1300F) #19
Mine is gear but it appears to have a canister where filter 27 would fit into. I changed my fluid but did not check that, now I wish I had. My 3 point is fast so I don't think I have an issue, but it would be nice to know it is in good condition. I do not have a loader.
   / Is my hydraulic pump dead? (Tx1300F) #20
27 is what is on a 3 cylinder model. 18 is what is used on a 2 cylinder model. I haven't seen a parts book that covers both 2 & 3 cylinder models.
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
