Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #681
Once you get your machine and get it assembled and filled with fluids, load it on your trailer and drive to a set of certified scales and pay to have it weighed.
Weigh the trailer before or after you weigh the ex on the trailer. Then subtract to get ex weight. Then you don't have to unload and load the ex at the scales.
hugs, Brandi
I just ordered a 1.5ton machine from an eBay seller... and got the shipping notice that lists the weight as 2,075lbs. Given that I don't have a scale handy that reads over 3000 pounds, is there a convenient way to know that I am getting what I ordered?
Interesting. Did you get the unit from La Puente, CA, for $8500 on eBay?
I would ask a lot of Qs of the seller. If they list another 1.5T unit, I will ask. Maybe they will name the factory in Shandong, or tell you the status of your machine's oil cooling and filtration. Maybe not.
   / Importing and modifying a new mini excavator from China #683
Honestly, they kind of did... the 1.5 ton units are significantly more money because they come with uprated hydraulics and the extra weight provides (or is alleged to provide) additional stability, which is kind of a thing for me because I'm going to be working a lot on sloping terrain.
My whole yard at the Cabin was 1 big Clay Pit, The JF12 is around a 845kg machine, so it weighs close to the same as a 1.5 tons would. Weight isn't your friend in Slop. in fact it causes troubles just doing the digging.
I got the Cistern in before disturbing any ground around it. Because once the ground got trampled, they Hoe wanted to sink. I had to cordaroy in some places.
Extra weight helps you from tipping over, but if you use the Bucket to trench more than the Arm, they can achieve a lot of work.
   / Importing and modifying a new mini excavator from China #684
The numbers in your post do not make sense, your calling it a 1.5 ton machine, your shipping notice is 2,075 pounds. I'd say you are getting a 1 ton machine, my math says a 1.5 Ton machine would weigh at least 3000 pounds.
   / Importing and modifying a new mini excavator from China #685
yep, that's exactly the one that I got. Seller is "peaktop". English is decidedly not their first language. I asked if they were certain they shipped the right unit, and explained that the weight was off. They said "yep, it's on the truck." I'll try asking again more specifically and see what I get back.
   / Importing and modifying a new mini excavator from China #686
Yes, that's exactly the problem. a 1.5 ton machine would weigh in at 3000 pounds. But the shipment apparently only weights 2,075. Which causes me to wonder if they've shipped me the right machine. I get that I could put it on a trailer and drive it to a scale, and I might need to do that, but I was hoping to avoid the hassle.
   / Importing and modifying a new mini excavator from China #687
Can't you look up the machine from another dealer and see what they list the weight as?
Re the actual weight, these 1-ton-ish units go by lots of names, cuz the makers invite you to stick your own names on the machines.
So I see lots of them called something like "QH12" or HT10, EM15, etc.
There are enough differences, including extra rear weights, that comparing to other machines is hard.
The Diggit EM15 I posted about above definitely seems to be a bit bigger than my XN08. 50% heavier (1.5T)? Dunno about that.
   / Importing and modifying a new mini excavator from China #689
I have found that weights listed for shipping are often inaccurate for imported type items. It might be due to conversion of Kilograms to pounds, it might be giving the weight of a similar item or it might be trying to game the system. If you look up the items weight in kg convert it to pounds and see if with crating your 2075 pounds makes any sense.
I have noticed that some of the minis over state their weight in pounds also. A 1.2 ton excavator weighs 2204lbs versus 2400lbs.
   / Importing and modifying a new mini excavator from China #690
New to the group. Just bought a Diggit em15 mini ex from Richie Bros. Sacramento Auction. $4,750. ($5,600) out the door. there were 4 or 5 of them and they all went for the same price.
Lost the roof on the way home. I'm planning on adding cooling fans and exhaust extension. Any other must do mods?
The hydros are very abrupt. Does anyone know if that is adjustable.
I'm going thru thread and learning alot.
Thanks,
1629 (A57192)
1629 (A57192)
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
