Calling Workmaster 75 Owners for a Question
   / Calling Workmaster 75 Owners for a Question #1
leeave96
Central Western VA
Wheelhorse 520H & 314-8
Been looking at a JD 5075e and now am looking at a Workmaster 75. JD has their owner manuals online for a free look and pdf download, but New Holland doesn’t - unless you register a serial numbered tractor. I’m just looking...
Anyhow - the vertical drawbar weight limit on the JD per their manual is 500 ish lbs. The drawbar probably can take more, but less loader, probably would get light quick on the front end IMHO.
Question - what is the max vertical drawbar load allowed on a Workmaster 75?
If you have an operators manual and could look and share that number, it would be much appreciated.
Thanks!
   / Calling Workmaster 75 Owners for a Question #2
Vertical drawbar weight limit 5075e is 2470lbs retracted position, 1675 lbs extended position, same as my 5085E. Can’t help you on New Holland
So when I look at the owner’s manual on John Deere’s website for a 2023 year 5075e and it says 552 lbs - that is a misprint?
   / Calling Workmaster 75 Owners for a Question #4
I would say it’s a misprint, the specs I read for the 5075e drawbar capacity were identical to my 5085E . Here’s the specs right from my owners manual.
The drawbar and framework on a 5075E is constructed differently (less beefy) than a 5075E.
   / Calling Workmaster 75 Owners for a Question #6
Hopefully someone with a 5075e will take a look in they’re owners manual for you. Yes on the drawbar frame being less beefy than the 4 cylinder 5e’s. However it’s still got to be designed to support more than 550 lbs . I’ve got a bush hog 1812 model 12’ batwing that has a tongue weight of 1100 lbs and it’s recommended to be used with 50-75 hp tractors. IMO no way in hell Deere would have a drawbar on that tractor with only a 550lb limit
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
2010 GMC Acadia SL SUV (A55758)
2010 GMC Acadia SL...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
UNUSED Hydraulic Skid Steer Mower Attachment (A47477)
UNUSED Hydraulic...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
