More 1845 Problems
/ More 1845 Problems #1
ernemats
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Yesterday evening my wife was mowing and she said it started making a squealing sound and she drove it about 50 yards and then decided she had better shut it off. I checked it and the hydraulic tank was almost empty and you could see a track of oil where it had been driven and where it was sitting there was quite a bit of oil on the ground. I think it is probably a leaking hose fitting or a hole in the hose, but I cannot see any. How is the best way to find a leak?
/ More 1845 Problems #2
First and most important is that a leaking hyd hose under pressure under the right circumstances can spray an almost invisible stream that can penetrate your skin! So don't use your hand to feel for leaks.
Fill the reservoir and check for leaks, if none clean/dry up the area and briefly start the engine and shut it down, look for flowing oil. Increase the time you run the engine until you find the leak, IF none then start using different controls until you find a leak. For example if it is not leaking at idle, switch on the PTO and see if the leak starts, if not, then try steering it or releasing the brakes or raising the loader arms etc.
/ More 1845 Problems #3
+1 on @m5040's suggestions.
One thing to do now, is to look on the ground and then under the tractor to try to see which drain hole is the source. Depending on how level the tractor is at the moment, that may, or may not, be helpful, but it might sort out a front end (steering/aux/FEL/front motor) leak, from an engine compartment leak.
I would add that I find it useful to power wash the engine compartment and dry it out before trying to find leaks. By the sound of it, what you are trying to find is not small. After a couple of leaks, I have gotten in the habit of keeping the engine bay pretty clean, so I notice leaks at the damp/slow weep stage, but sometimes it is just that a metal nose end cracks, and you suddenly have a big leak.
Good luck!
All the best,
Peter
Tractor is sitting on a side slope with the driver side down hill and the oil has been leaking out the hole where the drain hole is for the engine. It is out in the middle of the field a good ways from water or electric sources When she was driving it across the field steering was ok and mower was still working. front arms were still holding mower up even after taking mower off they held position.
/ More 1845 Problems #5
Well that would seem to narrow the areas quite a bit. I would think about starting to look at the uphill motor and its connections, and perhaps the hose connecting the left side to the right side. I would also look over the hose fittings on the pump.
Pictures might help.
When I have had a motor blow a seal, oil pours out pretty quickly.
All the best,
Peter
/ More 1845 Problems #6
It would be helpful to look it over now with a fine tooth comb as the old saying goes. With gloves move the hoses around to see under each, especially where they may be chaffing with another hose or a sharp edge. They can wear right through and burst under a load. Hose may have metal wires coming out.
You will need to refill the hyd tank and look, it may start leaking as you are doing it! It is a messy job, but you gotta get it done.
Just FYI, are you aware they have a tow valve so you can move it closer to civilization?
Have not done any checking yet but will do possibly today. One thing that does not make much sense to me is that both rear wheels have oil on the inside side walls and there is some oil on part of the cooling fan for the hydraulics and the top of the pumps are dry. I plan on jacking up the lower side to get it level and then drain oil lying on bottom of the tub, clean it as much as I can and check for leaks .
/ More 1845 Problems #8
If the cooler has oil on it and the engine doesn't, I would start looking at the cooler. They can slip downwards and rub, causing a leak, or the fittings could get loose or crack.
I suspect that both motors having oil is probably related to oil sloshing around, and not necessarily a sign of trouble for both motors. One, perhaps.
Good luck.As @m5040 points out, you probably need to get it clean, look around, for leaks. If you don't find any leaks, then refill, check, if you don't find any leaks, then power up briefly, if you haven't found anything yet.
Good luck,
Peter
/ More 1845 Problems #9
One thing I have found very useful is oil leak detector.
You can get a kit at Autozone, Amazon, etc..
Dye, flashlight, UV glasses.
It's a UV dye you add to the oil. Then use a UV light to look for the source while wearing the glasses.
So you'd clean the engine bay judiciously to get as much oil and grime out of it as you can and dried out. Then you refill the oil reservoir. Start the tractor up and let it run just a minute or so, and then check the engine bay with the UV light. You'll see the leak source pretty quickly.
If you don't see it, run it again for another minute and repeat.
I do this at night, or in a dark garage, because it's hard to detect in daylight.
I've used it on engine oil, hydraulics, antifreeze/coolant systems, etc.
Might be worth a try.
A little update. Today I cleaned tub the best I could where it is located, then this evening about dark my grandsons and I started it up and let it run for a minute or so no leaks could be seen , turned steering slightly , raised the lift arms nothing. I had removed the mower so did not check the pto circuit. The oil tank has about 5 inches of fluid in it yet so I did not add any yet as I did not have any in ,stock, will get some tomorrow . Before I did anything today I jacked the lower side up to almost level. We are leaning toward wheel unit circuit lines .
Sort of know the problem now. Put 5 gallons of oil in tank and started it up , no signs of any leaks, turned steering with brake on made noise. Took brake off and moved it about 3 foot forward brake still made noise . Left brake off and looked under pump and I could see oil flowing from a group of hoses that are all together and several layers high. Can't tell exactly what hose or fitting is leaking. Will call Terry tomorrow and see what he has to say. Need to clean that area out better.
/ More 1845 Problems #12
Good luck, that is probably the worse scenario, at least in my mind. To try and pull the bad hose out! Better attach the replacement and pull it through.
/ More 1845 Problems #14
/ More 1845 Problems #15
You may want to replace other hoses that show similar degradation to the failed hose otherwise you could be doing this at regular intervals.
The Ryobi is what I have been using but it does not have enough pressure for some jobs. Comes in handy.
Hopefully got leak fixed. The leaking hose went to the right rear brake. It came off a T under the pump and went to right rear brake about 21 inches long. Had a custom hose made today as the fittings were different on the 2 ends one was jic 4 and other end was jic 6. Was a real bear to get on the rear brake as it is partially under the frame and several larger hoses to the wheel motor not much room to get your hand in and see what you are doing. Started tractor up and released brake and did not see any leaks, now just need to add more hydraulic fluid to tank.
/ More 1845 Problems #18
IIRC, the 1845 has a motor mount without a lot of access. Is that right?
That must a heck of a job. Have you tried a crow's foot wrench designed for flares? aka a fraction flare nut crowfoot?
On my 1445, I have had to do this a couple of times, and I find removing the tire helps with access to the brake line on it, but I don't know about a 1845.
I know, I know, another tool...
All the best,
Peter
/ More 1845 Problems #20
Many flare wrenches will not fit over the hose in order to slip on to the nut.
Ken
Too true. I do have a set of flare wrenches that seems to mostly work over hoses. The opening is polished a bit more round and usually makes it over my hoses. I guess one could always sacrifice some perimeter coverage for a hose fit with a bit of grinder work to make a custom tool.
Standard crow's foot can also work, but in my experience, they tend to be much bulkier.
All the best,
Peter
DIAMOND TOOLBOX (A68842)
DIAMOND TOOLBOX...
John Deere 4040 Tractor (A64047)
John Deere 4040...
1998 KENWORTH W900 TRIAXLE (A67714)
1998 KENWORTH W900...
Year: 2011 Make: Hyundai Model: Sonata Vehicle Type: Passenger Car Mileage: 238,660mi Plate: Body (A66738)
Year: 2011 Make...
2012 PETERBILT 348 (A67714)
2012 PETERBILT 348...
X (A68191)
X (A68191)
