Loader arms uneven
/ Loader arms uneven #1
Canchaser001
JD 4044E
The arms for the loader are moving unevenly, which makes it very difficult to change the bucket and forks.
Has anyone else had this problem? Thoughts and solutions?
/ Loader arms uneven #2
Curl or dump it all the way so it aligns both sides again, and then put a new bolt on that shiny round cross bar that times both sides together.
They move independently, and when the right one reaches the full extension the other seems to fall into place.
/ Loader arms uneven #4
The chrome looking rod is all that holds the 2 sides parallel. It is just a piece of tubing as far as I can tell. Mine is the same way, I just curl mine back and forth, usually they will eventually find a place to rest that's close enough within a cycle or two.
/ Loader arms uneven #5
Isn't there a bolt at each end of the tube that would keep both sides timed correctly?
/ Loader arms uneven #6
There is, but apparently the holes elongate over time. The bolts are in both sides of mine but there is still enough slop that I can't pick up a loader attachment without fiddling with it but usually it's pretty quick to find a spot where they line up so I haven't even tried to fix it.
/ Loader arms uneven #7
The shoes will never move the same speed because of different resistances in the cylinders. If one moves easier or first it is because there is more drag or resistance in the cylinder on the other shoe. They will balance out when hooked up, even though it takes a little maneuvering to get them hooked up.
All that silver rod does is makes a pivot for the shoes. If the bolts are securing each arm, it should be alright.
/ Loader arms uneven #8
Oh ok. That's what I was trying to say to the OP. Almost looks one of the bolts broke.
3146 (A63117)
3146 (A63117)
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
