Toro Groundsmaster 322D fuel issue
/ Toro Groundsmaster 322D fuel issue #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
looking for ideas, last night my Toro 322D started spraying diesel on the injector side, Kubota 3 cylinder, tried tightening the nut but it was a small crack in the line injector end just at the ferule, looked at ordering they have to be made and looking like 5 plus weeks, my first thought was to braze the area and get me out of a bind,
any other thoughts or ideas, local shops say because its the high pressure line its not able to be made.
sucks but first breakdown for many years, one thing the clamps that should be on the 3 lines are missing, Im guessing its vibration that causes the crack would these clamps avoid the issue
/ Toro Groundsmaster 322D fuel issue #2
correct, dealer has to order it from Toro, not a stock part has to be made, part number 42-8140 pipe assembly fuel injector #2, tonight I roughed it with emery cloth, cleaned well and brazed the tube to the collar, after installing, bleeding its running but no idea how long it will last, will add a picture in the morning
/ Toro Groundsmaster 322D fuel issue #4
My 1990 322D has a Mitsubishi K3D engine, I thought all 322Ds had that engine.
Might be able to get fuel lines from some other source.
/ Toro Groundsmaster 322D fuel issue #5
Usually any fuel pump shop can either make it or has a source that makes them..
Take the line with u..
yes called the few shops in town, they say they only do low pressure this is high pressure to injectors, one would not do it due to the bends anyway one on order be in for next year, here is the temporary fix, used it for a couple hours last night and no leaks though I know its temporary and check it for the crack coming back
never figured it was a Mitsubishi the dealer said Kubota, now I have to take another look, it would explain why the Kubota dealer looked at the line and said he had nothing like that
Xfaxman you are 100% correct its a Mitsubishi K3D engine, learn something new every day, looked at the service manual it came with and written at some tine a dozen years ago is Kubota 3 cylinder, did call around to the local shop and seems same issue with the fuel line, non stock item special order, for now the repair will suffice.
This machine was a junk pile when purchased, the fellow who had it spent a lot of time and money on it and finally traded it for a zero turn, it went thro auction as is and cost a whopping $250.00, loaded it up and put it back together other than a couple hoses and gaskets its been great, had some electrical issue, some times it starts and shuts down after 30 seconds, other times it will not shut down but after turning the key 2 or 3 times it shuts down.
Last year as no brakes work and the wife wanted to try it I installed a couple brake cables, the brakes are not great, my thought is the adjusters in the drums need adjusting or something has seized but it will stop eventually.
anyway all is good, weather is still nice and not had to cut grass much this year
/ Toro Groundsmaster 322D fuel issue #8
looked at the service manual it came with and written at some time a dozen years ago is Kubota 3 cylinder,
Maybe it is for a 325D.
good point, its missing fhe first few pages as the back, just downloaded the right service manual and parts diagrams, mine definatly was not the right manual, close but not rifgt
quick update, the brazed line is still working however last night the wife ran the mower and it died, took a look the right side of motor is covered in fuel, figured my patch job failed but closer looking its number 1 injector line this time, broke the end right off, I never knew these lines were so thick, its close to 1/4 diameter and the hole thro is only 1/32 diameter.
took the line off and cleaned it up, pulled out the brazing cart and using a jig was able to align the end up and brazed it, another temporary fix, ordered a new one from Toro, $185.00 not cheap but given this pipe is so thick its not like brake line material, be here in 3 weeks lets hope the brazing holds up.
my question is this common, this will be 2 injector lines that failed the same way a year apart, did the previous owner stress them at some time or is it from vibration when running just fatigued the material, the lines do not have the 2 clamps that hold them together so maybe this would and avoid the vibration fatigue.
any comments or ideas are appreciated
well installed the line on number 1 cylinder, turned the motor over to bleed the line at the injector and as much as I tried the motor refuses to fire, not even any smoke, the lift pump is running, Im thinking it shut down from no fuel so when it stops raining plan on bleeding the system starting with the rubber lines then the injectors.
am I missing anything? now its not getting any fuel whatsoever
fuel shutoff is working as it should, bled air out the system, it was obvious when I loosen the line on the injectors 1 and 3 made little difference but 2 was obvious the rpm dropped, still thinking its air but started pouring down, will take another look tomorrow
/ Toro Groundsmaster 322D fuel issue #14
laurencen spray your ignition with a silicon spray that should help to
lub parts to keep from sticking
willy
I will give that a try for sure
well now its screwed up, the temporary fix on the injector line is temporary, just got a call from the Toro dealer locally the replacement line is discontinued, they have no suggestions how to get one, anyone have any suggestions, local shops are no help and Im out of ideas
any and all help is appreciated
thanks
/ Toro Groundsmaster 322D fuel issue #17
First u have to figure out what size ends u need.. both inj pump AND injector..
Hint: take a METRIC wrench, use the box end and fit it over the connector.. it’s either gonna be a 12mm or 14mm..
Now plug that # in Google as written & look for the correct ends..(12-14mm)
Ex: 6x2x600 injection pump line
They make a flexible emergency line w different ends but I haven’t looked for it.. I’ll leave it up to u..
Good luck
