Moving from 1/2 ton truck to HD truck
/ Moving from 1/2 ton truck to HD truck #101
Take your time and look extensively , look far and wide take your time and acce nothing less than your looking for.
/ Moving from 1/2 ton truck to HD truck #102
Have a very sweet Ram 1500 Hemi truck I got new (leased) last year.
Been thinking about moving up to a HD pickup to make towing my big enclosed trailer easier. Diesel HD trucks are insanely high in price. Even with 150k miles on them, you’re looking at $50k around here. So I opened my search up to gasoline HD trucks as well. I found a 2021 Chevy Silverado 2500HD with the new 6.6 gas engine. Sweet truck, extremely well cared for. Problem is, the 6.6 gas is a 400 HP engine. The axle is a 3.73. The trans is the old 6L90 that’s been around since 2006 and the ratios are really tall. So, I threw that combo into a spreadsheet along side the same info (power, trans ratios, axle ratio) from my Ram 1500. Looks like my Ram has significantly more pulling power in every gear, despite the 3.21 axle ratio. If my truck had the 3.92s it would be a bloodbath. But yeah, power/gearing advantage from 0 to 70 miles per hour. AND my truck is 1,500 lbs. lighter so that increases performance even more over the HD. I get that a HD truck is heavier and therefore in theory should handle/steer better with a trailer but I have a hard time justifying a move up to HD to get worse acceleration, fuel economy, and maneuverability. Sigh…
The Ford gas HD trucks can be had with 430 HP, 10 speed trans, and 4.30 gears which is a stellar combo but they are like finding a needle in a haystack. I can’t find one in my price range anywhere in this entire region.
The Ram HD gas trucks are nice but they seem to be abused on construction sites or work sites and by the time I find them on the used market they’re pretty rough.
"When going to HD trucks, go straight to 1 ton"? That’s what I was thinking too. But I looked up the tow chart from GM’s own website and it is surprising. The 2500 gas can tow more than the 3500 gas (only a couple hundred lbs., likely the difference in weight between the 11.5 and 12.0" axles). The payload gain on the 3500 is less than 500 lbs. If you go diesel then there’s a couple thousand lb. advantage for the 3500, but that’s not really a huge deal either. Surprising though that on the gas trucks the difference between “3/4 ton” and “1 ton” is almost zero on paper.
If it's for towing you should be looking at torque numbers, where they get close to peak numbers, and how long they stay up there. The lower the RPM that torque comes on the better. Peak horsepower numbers do matter too but if you have to rev to 5-6 grand to take advantage of it, it won't amount to much with a trailer behind you. That said, the main advantage to the heavier pickups is that they're just physically heavier and handle a trailer better without being pushed around. Honestly before I had a 3/4 ton pickup, even with the only 165 HP half ton I never had a problem getting the load moving so much as stopping it and feeling stable going down the road. Hills were a bit of an issue too, but it did better than you'd think there as well. Now I've got literally twice the power, 100+ more ft-lbs of torque, 115 more cubic inches, and what feels like 10x the capability. I didn't even take a hit on MPG either. Most of that boils down to aero anyway, especially on the highway. If I was looking right now for a gasser I'd be eyeing the 7.3 Godzilla but I don't think you'll be disappointed in the GM 6.6 either. Now this is not an apples to apples comparison, because you've got plenty more power in your current half ton than I did, but my other points still stand. 3/4 or 1 ton pickups are superior in every other way.
/ Moving from 1/2 ton truck to HD truck #103
But...but...J9807 and the salesman said...
/ Moving from 1/2 ton truck to HD truck #104
To the OP - glad you found one to buy that fit your needs. As long as you are happy, and it sounds like you are, that is what matters. Not feeling comfortable towing something, feeling like you shouldn't be doing it, is a bad thing. I am on step 3 of my 3-step plan. Tractor too small, buy bigger tractor - WM75. Now trailer too small, buy bigger trailer - Big Tex 14GN 20+5 with Mega ramps. Now truck too small, buy bigger truck. I have been looking and had trouble finding one I liked. I finally found one in transit. It's a 2024 GMC 3500HD dually with the Duramax. Just waiting for it to show up at the dealer. It will look like this one except it doesn't have power steps, just factory chrome steps. Dealer said with those, I don't have to turn in my man card.
/ Moving from 1/2 ton truck to HD truck #105
I beg to differ. It's a really good thing when people feel like they shouldn't be doing it, I think.
Way too may oblivious drivers out there who apparently think there's nothing wrong with having a trailer oscillating behind them.
/ Moving from 1/2 ton truck to HD truck #106
I agree that as a safety factor getting that feeling, knowing when you are doing something past your capabilities, is a good thing. I try not to have that feeling that I am pushing me and my equipment past our limit. When I get it, I know it's a bad thing, and remedy the situation.
/ Moving from 1/2 ton truck to HD truck #107
Why are people so adverse to an older clean Western truck. Like an OBS Chevy or GMC out of Oregon or Idaho with a perfect rust free body, needing slight maintenance and upkeep, those trucks are built 100 times better than anything you can buy new. Furthermore for 8-20 grand you save real money, parts are available and they are easy to repair.
If it’s a GM product it’s going to need a transmission. It’s a known problem , currently with a class action lawsuit. They were junk anyways, then used the wrong fluid but instead of owning up to it and doing a recall they put out a TSB… when these symptoms occur change the fluid and charge the customer. Any damage done to the transmission is also on the customers dime. They don’t stand behind their product and I will never own another GM for that reason.
/ Moving from 1/2 ton truck to HD truck #108
Neighbor just had a transmission replaced on one of his 6.0 fleet trucks. I think he said it was out of warranty and he was surprised it was fully covered. Maybe different dealers in different areas can get positive results. :unsure:
/ Moving from 1/2 ton truck to HD truck #109
Some people either don't have the time or ability to do their own work. You are saving boat loads of money if you can do the work yourself but if you cant the savings is severely diminished. Also if you can't do the work you are at the mercy of your mechanic who may be a superstar or a butcher. I myself agree with you though. My "newest" truck is a 2003. But I also do all the work.
/ Moving from 1/2 ton truck to HD truck #110
Can't figure one thing about "modern" trucks and towing.
Leave me explain -- Please. Do we need 800+ horsepower in a pickup??
Back in the 70's I hauled combines with a White Compact with CF 160 Cummins. Also hauled equipment with a 3/4 ton Ford F250 with a 354ci 120 horse Perkins diesel. When the Cummins in the White "died" (The boss himself spun a main bearing) The boss bought a larger White 9000 series I believe with a NH 220 Cummins.
Back in the 40's the fellow I worked for worked for a garage that had a contract with Tidewater freight. They hauled freight with Ford trucks that were equipped with flat head V8s with what 85 or 110 horses?
Even now most of the over the road tractors don't have the horses that modern pickups do.
Might be great to brag about a barnful of horses, but they need to eat.
Yep, as a young "kid" my first car was a 150 horse Corvair, 2nd was a 318 Charger with 340 cam and 4 barrel carb, 3rd was a 383 RT Challenger. One thing they all had in common was power AND 10 mpg. Of course that is when gas was cheap!!
2019 John Deere R-4038 (A61306)
2019 John Deere...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
