Need Help Framing a Turn-Down-Slab
/ Need Help Framing a Turn-Down-Slab #1
LittleBittyBigJohn
Central Arkansas
John Deere 1025R, Kubota ZD1211
Title says it all. I have my pad built and I think there may be a picture in my shop thread. I wanted to break this thought out so there would be more visibility and hopefully I'll get some good thoughts. I'm planning on renting a mini-x this weekend and getting it ready for concrete. I have 2 things I need help with.
1) I want to dig the footer turn downs to the finished size and add forming above instead of digging wide and using 2x12 boards all the way to the bottom of the footer. This way I can save money on boards and get a little deeper footers. But, I've never formed anything and I don't really know how to make it all line up and hold together.
2) How do I get 4 runs of re-bar to hold together. I know there are rebar chairs that will hold the bottom 2 off the bottom but I don't know how to elevate the top 2.
/ Need Help Framing a Turn-Down-Slab #2
We always used wood stakes and tie wire. The outer form is set and the grade is finished. Then a wood stake is laid across the footing resting on the form board and the slab grade. Tie wire suspends the rebar from the wood stake. The footings are poured first, the wires are cut, wood stakes removed, and the slab is poured all in a single pour. Remember to overlap your rebar joints 40 times the bar diameter.
/ Need Help Framing a Turn-Down-Slab #3
Typically, if you want 4 rebar, you would tie it up like a box, and place it all together. easiest way, would probably be #2 smooth ties, in a square, and tie your 4 bars to that. You can tie the boxes up as sections, and overlap (check your local spec for requires overlap)
/ Need Help Framing a Turn-Down-Slab #4
That is some serious overkill - I'm certain the engineering simply calls for 4 bars - no hoops
/ Need Help Framing a Turn-Down-Slab #5
You could take a #3 rebar, and wrap it around a 6x6 or 8x8 timber, making the squares, order them from any rebar supplier, use a rebar bender, or even the ball on a trailer Hitch (hard to keep it exactly uniform). Once you have your squares, tie one every 4 feet or so, with the bottom 2 #4 bars (odd they spec 4-#4s, I stead of 2-#5 or 2-#6), then put your
top 2-#4s, tie them as well. The 'beam' will be kinda floppy, so don't think you can lift/place more then max 20ft at a time. The bottom of the box will need supported by chairs or a'dobe' bricks. (basically a solid brick with a 2 tie wires in the top of it.
Another possible option is driving 2 verticL rebar stakes, and tieing horizontal bars. Issue is, the stakes will be exposed to rusting (bottom of stake js in plain soil not concrete), which will eventually wick up, and over the years (or decades) allow your horizontal bars to corrode.
/ Need Help Framing a Turn-Down-Slab #6
A ghetto option, (not endorsing), is pour 3-4" of footer, lay bottom 2 bars, pour next 4" and add 2nd 2 bars; not how I would do this, but in residential type work, I'm sure it happens a lot.
Edit: I don't mean pour, let set, add bars, and pour new on old, that is beyond ghetto, and is a a disaster. Do not do.
/ Need Help Framing a Turn-Down-Slab #7
You can also look for some 4" tall dual bar chairs, and then some 8" tall dual chairs, and not tie anything but laps and corners.
/ Need Help Framing a Turn-Down-Slab #8
Looks like a #3, 6"×8" rectangle stirrup is 4.08 Cunuckistan Copek, or about $3/each. Trouble will be finding them in stock, but Whitecap and many other custom bend rebar.
/ Need Help Framing a Turn-Down-Slab #9
Your project is almost identical to one I had done over 20 years ago. I did not do it myself but paid close attention to the work that was done.
The area had been cleared, flattened, and leveled (supposedly) prior to the form work.
The area was laid out using 2x4 corner posts and string pulls to designate the area to be formed and poured. A transit was used to establish the string heights as well as to ensure they were level. 2x6s were used to make the forms using 2x2s posts pounded into the ground every 4 ft as backers to the forms.
The footer area was dug by hand (quite a feat in our red clay). The dirt that was removed was used in the areas where the forms and existing grade had gaps. The rebar in the footer were supported by pieces of broken bricks both at the lower level and the upper level.
The total pour was 24ft x 40ft and was done in two pours over two days. After the concrete had cured for about a week, the area was cut into 4 sections (one lengthwise and one widthwise using a diamond saw) to minimize future cracking. To date, there have yet to be any cracking in the finished pad.
/ Need Help Framing a Turn-Down-Slab #10
On item #1; you are correct, earth form bottom/inside, form boards on the exposed portion of the outside. Spray with diesel or release agent will make stripping easier. Account for some additional waste/over run on concrete, maybe 10% of the FOOTER total to account for the less exact dimensions when earthformed.
You are saying I can just dig the lower portion of the footers and not frame the bottom 12"?
/ Need Help Framing a Turn-Down-Slab #12
Around here, that design is typical, monoslab, and although you might pour the FOOTER portion first, you will pour footers and slab as a single placement to avoid any cold joints. IE, truck#1 pours (or pumps) the entire perimeter FOOTER, truck #2/3/4 pour the flat work, and everything is a single, monolithic slab, or thickedge slab. Probably 95% of homes in this area are poured that way. Stem walls are almost unheard of, here in N Fla, but we aren't dealing with freeze-thaw, or mountain sides, where a stem wall can 'step' up or down on the grade.
/ Need Help Framing a Turn-Down-Slab #13
Correct. Only the exposed part, and maybe a couple inches below, to prevent blow outs. Place 2x4 stakes every 4 ft to keep things straight; concrete is Heavy, and that weight will want to bow the form boards out.
I need to look back at your drawing; but; how much of the slab/footer is exposed? If it's more then say, 8-12", you might need stacks and kickers, as well.
The drawing is pretty vague, it's the picture on the first post. He said the biggest thing is just to make sure there is 12" under ground. I was planning on 12"x12" footer with the 4" slab on top of that. So the footer portion should end up about 16" thick.
I have an option of a 12 or 18" clean out bucket. I don't know that I need to go 18" wide on the footer?
/ Need Help Framing a Turn-Down-Slab #15
Quick sketch. Looks like a 2x10 form board will be plently; and for that, I dont feel kickers will be required, as long as you don't use 2x2s or 1x2s as your form stakes. Also attached a generic image, that I think, explains a bit of what I mean about just forming the exposed face.
/ Need Help Framing a Turn-Down-Slab #16
The 12". Once that native ground or fill is over excavated, you will either have to form it, or deal with Major over runs in concrete. It's very difficult to add material back with earth forming.
/ Need Help Framing a Turn-Down-Slab #17
A 12 bucket will net a 12" plus footer depending upon the soil, rock content, and operator skill. I set forms commercial and residential for 30+ yrs. Use steel stakes upright every 2ft with a wood kicker. Assume a 6" form and possible 4" under crib where needed. No need for forms underground if it's dug properly. There should be a kicker at every stake. String line your forms when kicking them.
If you have never set forms or poured concrete before hire somebody to work with you who has experience. Forms gone bad are a nightmare.
/ Need Help Framing a Turn-Down-Slab #18
Word of advice, drive your stakes down flush, or below flush with top of form board, or cut off flush, or you will be cursing while screeding the mud. Have strings set on forms, and check while mud is still not set, so you can push back in, and add stakes to anywhere that might have bowed out. You can also always throw some fill on the outside of the 2x10 form to help prevent blow outs or bowing.
/ Need Help Framing a Turn-Down-Slab #20
Generally, saw cutting the control joints within 24-48 hours is desirable. They don't prevent cracking, they Control where the cracks happen. Depth of the cut should be about 1/4-1/3rd the thickness of the Slab (not footer); so 4" slab=1 to 1-1/4" depth of cut. 6" slab, try for 1.5-2" depth of cut. Tooled control joints look good, but don't work as well as sawed joints. Your plan shows 6x6 WWF, which I personally am a big fan of, even though the world has moved towards fiber reinforcing. As someone who has demo'd slabs, I can tell you, it's harder to break up concrete with wire, then it is concrete with fiber.
Edit: assuming that WWF is IN the concrete, not under... it has to be supported or pulled up, as the pour goes along.
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2016 Ford F-550 Flatbed Truck, VIN # 1FD0W5HT7GEC46417 (A65563)
2016 Ford F-550...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2014 Ford F-250 Utility/Service Truck, VIN # 1FDBF2A67EEA87424 (A65563)
2014 Ford F-250...
1995 WILSON PACE SETTER DWH-400 HOPPER BOTTOM TRL (A64277)
1995 WILSON PACE...
