'Professional' grade saws vs. 'Homeowner' saws
/ 'Professional' grade saws vs. 'Homeowner' saws #61
I still have both style of saws for different reasons but more and more I reach for the computer controlled saws it’s nice not having to adjust stuff constantly to keep the saws running at their best at all times.
Try fixing a computer saw in the field or running less than optimally water free fuel through it. No way would I buy a CM Stihl, so glad they brought back carbureted 261s.
/ 'Professional' grade saws vs. 'Homeowner' saws #62
14" for a top handle running applicable chain.
There’s a big difference use to be anything in the 20’s was a short bar 30’s were the standard and 40’s up were long bars.
I’ve ran those 555’s and 562’s since they’ve come out without issues we run standard pump 87 E10 fuel through all our saws I’ve never had an issue.
/ 'Professional' grade saws vs. 'Homeowner' saws #63
Been looking at used saws…..what people want for them is ridiculous.
I see saws that cost $599 new and they want $500 or $899 new and they want $750.
Who would take that kind of chance to save ~$100 bucks?
My Stihl dealer usually does ~10% for tools and a little more for parts. Never hurts to ask.
Also, 10 years from now do you want to have to buy a replacement because you wore out a homeowner grade saw or still be running a pro grade? Stihl ranch saws are also a great saw even if running them very often.
/ 'Professional' grade saws vs. 'Homeowner' saws #64
This was done where the 562’s were done when it was almost brand new.
the upper is of the 385 I used was breaking in cutting second growth and still do when it’s called for. The other is a 395 setup to pull a 60” bar reason for that long of a bar is the property line right behind it and stumps out in front of the tree.
/ 'Professional' grade saws vs. 'Homeowner' saws #65
If we all believe that anything with more than two parts will eventually wear out and/or break. Will you be able to repair it when it does eventually break?
/ 'Professional' grade saws vs. 'Homeowner' saws #66
/ 'Professional' grade saws vs. 'Homeowner' saws #68
Yes I will, it’s just a carb on those saws and honestly most of the time by the time I’m done with a saw they’re worn out in the bottom end anyways. Normal schedule for me is one top end and then run it for a while then either get rid of it or scrap it for parts, by this time the bottom end is getting loose in this application you’re putting a lot more strain on them then firewood would.
/ 'Professional' grade saws vs. 'Homeowner' saws #70
That is because you are using them often and that don't apply to ocassional users where the saw sits for a prolonged time. Put E10 (with mix of course) in a saw and let it sit for a couple months or longer without use and report back....
/ 'Professional' grade saws vs. 'Homeowner' saws #71
If you think I run all of these even weekly that’s wrong heck even monthly, that 395 sits with gas in it from a year ago you pour it out put fresh in it and she runs without issues, 390 same way. Moral of the story is I do let them sit with e10 without issues maybe I’m lucky or maybe it’s as simple as the fresh gas when I go to restart and then run them hard. That’s not the full collection of saw either it’s missing the 3120 and echo 1201 as well the 500i plus the 462 a lot of those sit a lot minus the 500.
/ 'Professional' grade saws vs. 'Homeowner' saws #72
Well I got some real bad news. My Makita/Dolmar 6401 has a scored piston/cylinder. Have NO IDEA why.
Now decision time, fix or move on?
Looking at the prices of quality new 65CC saws with 24” ain’t fun, either.
/ 'Professional' grade saws vs. 'Homeowner' saws #73
With makita dropping the gas line can you still get parts? I’d bet the saw had an air leak leaning it would be why the cylinder is scored.
/ 'Professional' grade saws vs. 'Homeowner' saws #74
I think so too. Felt like it was running “lean“ last few times, too.
/ 'Professional' grade saws vs. 'Homeowner' saws #75
View attachment 815818If you think I run all of these even weekly that’s wrong heck even monthly, that 395 sits with gas in it from a year ago you pour it out put fresh in it and she runs without issues, 390 same way. Moral of the story is I do let them sit with e10 without issues maybe I’m lucky or maybe it’s as simple as the fresh gas when I go to restart and then run them hard. That’s not the full collection of saw either it’s missing the 3120 and echo 1201 as well the 500i plus the 462 a lot of those sit a lot minus the 500.
So you have a ****te load of saws. Means nothing to me. I have 3 plus the 090 and 075 and they are both dry and will stay that way. I only really need 2 actually and all mine are on canned gas (Echo Red Armor) anyway. To me, a chainsaw is only for ocassional use anyway. Nothing more.
/ 'Professional' grade saws vs. 'Homeowner' saws #76
The older I get, the smaller the saw I grab first. :)
/ 'Professional' grade saws vs. 'Homeowner' saws #77
Let me know if you decide to junk it.
I would consider a rebuild of that saw worth the effort (to me)
/ 'Professional' grade saws vs. 'Homeowner' saws #78
Isnt that the truth. Even the little echo 490 with 18" starts feeling heavy after cutting for longer periods anymore.
Dang as light as 50cc gets too
I'm always grabbing for the smallest saw that will get the job done in a quick manner.
The 71cc 77cc 94cc set in wait for the need.
I counted 19 runners on the shelves other day. I thought or was hoping I was below double digits now. I been selling stuff off since 2010.
/ 'Professional' grade saws vs. 'Homeowner' saws #79
I find it comical that people go to Lowe’s and buy a husky and think they have a pro saw. It’s like people getting a John Deere from Home Depot and thinking they have a good mower
/ 'Professional' grade saws vs. 'Homeowner' saws #80
Same with Echo. What in the world are they thinking?
I have no use for anything from those box stores.
Stihl is one of the few left who is doing it right. The day they go “box store” is the day they will start going downhill.
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
JOHN DEERE 850K WT CRAWLER DOZER (A62129)
JOHN DEERE 850K WT...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
