/ Share Pics of People Hauling or Towing Something Wrong #18,602
I saw one like that in Ohio recently.
/ Share Pics of People Hauling or Towing Something Wrong #18,603
When you use plastic for an air foil you have to expect some failure. I haven't had one last in a pickup in years. Luckily they aren't quite as much of the structure so that when they fail I can take them off.
/ Share Pics of People Hauling or Towing Something Wrong #18,604
All his straps except 1 had the winch on the right. The one was next to the back one like he was trying to fix it. He looked nervous when I passed him.
/ Share Pics of People Hauling or Towing Something Wrong #18,605
All his straps except 1 had the winch on the right. The one was next to the back one like he was trying to fix it. He looked nervous when I passed him. View attachment 815512
Clearly someone doesn't know how to stack pipe.
Good thing the Tesla got safely past!
Any chance the load hits the underpass?
/ Share Pics of People Hauling or Towing Something Wrong #18,606
No it was not that high. It's a hot shot truck pulling a gooseneck. Later the same day I saw a Ford Super duty pulling a dump trailer. He had a pallet of pavers on the rear. Every time he got up to about 30 MPH the trailer would start violently swinging side to side. I didn't get any photos I just wanted to get past him before he crashed or the trailer popped itself off the ball. Some paver company name on the truck. Idiot behind the wheel. Crowded freeway during afternoon rush hour. But the pipe was 4 bundles in 2 stacks. 2x4s top and bottom on each bundle with steel strapping. They are stable if the straps are pulled in both directions evenly.
/ Share Pics of People Hauling or Towing Something Wrong #18,608
I'm not a trucker, but I believe the rachets are required to be on the passenger side of the trailer, so that any adjustments will put the driver on the passenger side away from traffic. Tightening the rachets will pull the load toward the rachet. Thus, there are times when it makes more sense to deviate from the "rules" to have a better balanced load.
/ Share Pics of People Hauling or Towing Something Wrong #18,609
We hauled thousands of loads of plastic pipe out of a factory in Bristol, IN from the 70s until the plant closed in 2009. Large pipe like that in the picture should have notched spacers between each layer, or its not going to stay stacked straight, ain't gonna happen.
The big secret to hauing plastic pipe is to stop often and retighten the straps. When we first started hauling plastic pipe, they allowed us to use chains, but that was a real nightmare and they soon required a minimum of 12 30 foot straps for a load.
Small diameter 1", 1 1/2" and 2" schedule 80 pipe got really heavy, one load we hauled was over 50,000#.
As to the strap ratchets, they are required to be on the driver's side.
There used to be a pair of sharp curves on SR15 south of Bristol that claimed 10 or 12 loads of pipe when the drivers took the curves too fast or had not secured the load properly. Usually made quite a mess.
/ Share Pics of People Hauling or Towing Something Wrong #18,610
I am a trucker. Have been for over 40 years. I've never heard of that rule. The law requires them to be alternated in many cases.
/ Share Pics of People Hauling or Towing Something Wrong #18,614
I stand corrected. I'd thought my information came from a trucker, but apparently not.
/ Share Pics of People Hauling or Towing Something Wrong #18,615
Anyone have a new one of these?
I added one to my GMC 2500HD and wow is the display dim. I contacted Curt and they were highly responsive and even sent me a complimentary replacement. But the display was the same as the one I had. They said they dimmed the display down because of nighttime driving complaints. I have no concerns about the quality, but I tow during the day most of the time. I wonder if the 51146 model would have been a better choice.
/ Share Pics of People Hauling or Towing Something Wrong #18,618
Good question. Those 3-dial combo locks are rated for at least 20k lbs, right?
All this setup just to lower the hitch height by a few inches? It's befuddling.
/ Share Pics of People Hauling or Towing Something Wrong #18,619
Just needs to cross the safety chains.
Bruce
/ Share Pics of People Hauling or Towing Something Wrong #18,620
Bet that's a blast to back up...
MMS 800 Remote Control Lawn Mower (A60463)
MMS 800 Remote...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
John Deere 4044M (A60462)
John Deere 4044M...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
