/ Share Pics of People Hauling or Towing Something Wrong #18,561
We had a printer that had a rotating type band, like a band saw, but with three rows of characters. That machine would lift a full box of paper if you tried (we did).
It had a sound deadening wood and insulation cover, and it needed it.
The SGI machines had a flight simulator and we used to chase each other from different terminals using commercial planes.
The LISP machine was the one I dreaded coding on the most, try counting parentheses and making them correct or your data came out weird.
/ Share Pics of People Hauling or Towing Something Wrong #18,562
The first SGI machines I used had Motorola CPUs, and came with the source code to the flight simulator for users to learn how to code SGI's 3D engine (name escapes me but is in most computers these days). So somebody tweaked the Cessna 150 performance to something quite excessive.
Later, MIPS CPU SGI machines did not include the source code to the flight simulator. But I suspect it was available. Just wasn't important enough for me to go find it.
/ Share Pics of People Hauling or Towing Something Wrong #18,567
Grew up on a fruit farm using that type ladder in the orchards.
Learned not to use them on a cement surface the hard way.
Why would I go get a 4 legged ladder to change some light bulbs in the barn?
These were right there.
That middle leg swings out as far as you need to set up around trees. It digs into the grass/soil and is very stable.
Not so on cement, as I painfully discovered.
The middle leg has nothing but friction to stop it sliding out to 180 degrees.
Concrete doesn't have much friction.
I was on top of an 10 foot ladder, fully stretched out to reach the bulb, when i was face first on the cement.
The middle leg slid out so fast I didn't even have Willie Coyotes moment of, "OH CRAP"
Surrounded by broken glass and in some serious pain I slowly got up. I was sore for weeks.
I use the right ladder now.
My tripod ladder is an orange fiberglass Werner ladder that has the normal ladder bracing so the third leg will not slip out from under you. It's my go to ladder for 90% of what I do. Very sturdy. I ran across it on sale for $90 and bought it immediately.
/ Share Pics of People Hauling or Towing Something Wrong #18,568
Interesting. No limit on mine. it's not unusual to lift the front leg high and put it through a crotch in a dense apple tree then plant it on the far side, to get in close and harvest the center of the tree.
I had to go out into the barn and snap a picture, mine are Ladder King. Up by the hinge there is a strap cable that limits the "intended" spread if the 3rd leg. I don't know if it would hold up on a hard surface. I only use them on dirt, so it doesn't matter to me.
/ Share Pics of People Hauling or Towing Something Wrong #18,572
LISP=Lots of Irritating Stupid Parentheses Took it in college and learned why I was not cut out for any real programming...
/ Share Pics of People Hauling or Towing Something Wrong #18,578
Redneck dumptruck! Back up and slam on the brakes!
I briefly worked with a guy who claimed he did something like that when delivering sheetrock.
He delivered a flatbed trailer load but the promised forklift wasn't there to unload it. After waiting all day and after everyone went home, he claimed he drove in a tight circle and slid the sheetrock off his trailer. Credible? I don't know.
/ Share Pics of People Hauling or Towing Something Wrong #18,580
How do they unload it???
Slip sheet forks or roller forks?
Dunno. I saw that on Reddit. Source not cited. It had many comments but none that knew anything.
So, Reddit as usual? :ROFLMAO:
Aaron Z
Freightliner Fuel Truck (A61307)
Freightliner Fuel...
CFG Industrial H12R (A60463)
CFG Industrial...
2010 Ford F-150 Pickup Truck, VIN # 1FTEX1CW9AFC54781 (A61165)
2010 Ford F-150...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
(2) John Deere 8 Row Markers (A60463)
(2) John Deere 8...
208735 (A60430)
208735 (A60430)
