Seat switch might be held down with rubber band or a piece of string but that is not full proof. You need to verify change of state from being tied or not tied. safety switched normally are in closed state, what that means the contacts on the switch are made with a help of some sort of spring and metal that acts as spring. So basically all closed switches make the circuit complete and if one of them opens up breaks the continuity. Now I am a ME and not EE but know enough electrical stuff to be " real dangerous"
 you can make a very simple test light combining a battery, wires, a light bulb and two alligator clips. Clips touch and the light comes on. With that you can check any single or double pole switches. What you want to be sure light illuminates with the switch is on and light goes off when the switch is off.
