Help with Front Blade attachment
/ Help with Front Blade attachment #1
ShawnLimy
Kubota B6200D
I have no idea how to attach this (I think it's a snow Blade) to this setup, I'm not familiar with Hydraulics or mounting anything on the front of the tractor, I only had a # point rear blade on my last Kubota. I know it's not a Hydraulic blade, but there is a Hydraulic cylinder, I guess for lifting the blade?
Does anyone have any idea what is going on with this setup? I'm the 3rd owner, the guy I got it from never had the blade attached, he just used it to cut grass on his farm.
/ Help with Front Blade attachment #2
It looks like the model number is still on the plow. Google it and see if you can come up with an owners or assembly manual for that blade. Also your Kubota dealer might be able to help. If you post a picture of the model number someone on the forum might be able to help with the manuals.
I didn't see a model number, just the dealers sticker on it, I'm not even sure if it's a kubota blade.
/ Help with Front Blade attachment #4
Looks similar to this setup...go to 1:40
You are right, it's very much like that setup, Only problem I'm having is, Trying to get the two pins on the blade into the two holes on the mounting bracket, Not sure if I have to take the bracket off the tractor, and mount it to the blade, theen attach it to the tractor.
/ Help with Front Blade attachment #6
Are the 2 pins spring loaded but rusted up? A good picture of one of those pins would help. I would assume that you would not have to remove the bracket to mount it. Flip the plow up on it's face so you can get a good look at those pins.
/ Help with Front Blade attachment #7
That plow blade is very likely a Kubota B2753A.
The quick hitch is a bit dated design and has been replaced with a different system on newer models.
I have the mounting scheme on my B7200 tractor and am presently actively looking to buy that same plow blade as in your pics ;-)
Not spring loaded, the pin length is 11 inches, and the opening of the bracket on the tractor is 9 1/2 inches.
I don't think it's a Kubota blade, I turned it over, and it looks like it was White before; and painted Orange.
/ Help with Front Blade attachment #10
OK
That is NOT the B2763A
It looks more like the blade mount for a BOLENS yard tractor, The HT series in particular.
I gave it another try on the front blade got it all hooked up hydraulic works great, Moved a little dirt today with it I know it's probably not for dirt but it worked fine, anyway I'm all set for winter thanks for all the help
2005 International 4300 Rollback (A62613)
2005 International...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
generator trailer (A61569)
generator trailer...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2011 Renegade Mobile Command Center Trailer (A61573)
2011 Renegade...
JOHN DEERE 6500 SELF PROPELLED SPRAYER (A64276)
JOHN DEERE 6500...
