Pivot pins
/ Pivot pins #1
Swblack1216
Washington state
Kioti ck25, Ford 4500
Ford 4500 Just noticed the loader attachment pivot pins. Two lowers are not grease able and one upper was replaced with a piece of pipe would like to replace all four .Nowhere to be found any help would be appreciated. 1 1/4” x 6 1/2 ” greaseable if possible. TIA
/ Pivot pins #2
If you don't have the capability you may have to get someone to make them for you.
/ Pivot pins #4
All pivot pins (fulcrums) need to be solid steel, not pipe and all should be cross drilled to accept grease fittings, no exceptions.
/ Pivot pins #5
Wow that sound spendy
Not really. Any good machine shop should be able to make them for you as they are a pretty straight forward piece. Order the bushings, 291548 before you have them made to give the machinist the ID dimensions of the bosses being made.
Parts book for the 740 loader show what they should look like:
Alternately, you could call a salvage yard and see if they would have or take off the bosses on a junk loader.
/ Pivot pins #7
You just might find them premade if you do a search. I was able to for my Volvo excavator. The size seems reasonable common. Or if you have the ability to drill the shaft as needed see how tight a grade eight bolt would be. Of course you will not have the threads in the bearing area.
/ Pivot pins
Thank you so much for the input great
/ Pivot pins #9
Pictures are worth 1000 words
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2021 Salford 550-30 Cultivator (A63116)
2021 Salford...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
207278 (A52708)
207278 (A52708)
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
