Glulam Beam - Checking Problem
/ Glulam Beam - Checking Problem #81
A timber screw with a fully threaded shank as you show can only provide a clamping force to the area directly under the head - and that force is limited becase it cannot exceed the the compressive stress of the fibers it bears on. The force is farther reduced by the angle of head.
Think about it: a fully threaded shank CANNOT pull two pieces of wood together, and the head angle only hurts that effort.
That type of screw is a poor choice for the purpose.
I am afraid that you need to find some competent engineering help.
rScotty
I would be concerned that their is no cinching power in that type of screw. Is the top of the beam accessible?
Adding epoxy and pairs of though bolts with backing plates to spread the clamping force would seem to be preferable to me.
But I'm certainly not a glulam engineer and I tend to believe that stout and stouter is better.
/ Glulam Beam - Checking Problem #82
That's what I would do as well. It concerns me that they would recommend a fastening that cannot provide any clinching or clamping forces. Why put the screws in there anyway? What are they supposed to be doing? The threads actually resist the clamping forces....
I am not a glulam engneer either, but that "fix" is odd enough to make me wonder if their engineering department has an degreed engineer - or if so, if their engineer has looked at this type of repair.
But just because the splits result in a beam is not as stong as it should be does not mean it is going to fail. Not at all. There is a lot of extra strength in the way houses are designed these days - AND in the materials. It is just that I join with several others on this forum in being a belt and suspenders kind of guy.
If it were mine, I would look ask another engineer - a local structural engineer - to estimate the importance of that beam. It very well might be small enough or overbuilt enough that I would just accept it and continue. Probably is. Or I might decide it is critical and use through bolts, backing plates, and yes... it wouldn't hurt to fill the cracks with some thickened epoxy as well. But having done one or the other, I wouldn't find something else to worry about.
BTW, it is good practice to use an end grain sealer on wet wood or dry climates or the reverse. There are special ones, but even a coat of paint helps. It allows wood to adjust to different humidity more slowly.
rScotty
/ Glulam Beam - Checking Problem #83
General gluing strategy is to get the glue in, then keep the wood under compression while it sets.
You can get epoxy tube/applicator tools that do a combined mix and injection that makes getting perfectly mixed glue into crevices easy.
I use those Simpson strong ties a lot, and like them, but look at the threads. They will only compress from the head to the top of the threads, which isn't much. My concern on the toe nailing is the lack of compression, given the depth of your beam. I would glue, then compress the beam, then toenail. But I'm neither a structural engineer nor a glue expert.
My primary use is of the Simpson strong ties is fastening a single 2by to something else, e.g. a 2x6 fence board on post. They can support the use of a washer, but the screws have a relatively small diameter, which is great for not splitting wood, but it means that they aren't lag bolts, and can shear if over torqued.
Glad to see the progress.
All the best,
Peter
rScotty
When we cut the beams to size, I immediately put a wood glue at the ends to prevent drying out. I used Titebond III on the ends to seal the exposed wood. It is a waterproof glue. Beams were installed in about 1 week after delivery and never got wet and the SIPS roof was installed the same day the beams were installed.
Even the 4x6 wood top plates split in some spots. They were also supposedly Kiln Dried but ended up checking and I had to replace one as it warped so badly it lifted 2"+. This is how wood reacts to this dry climate. Hence why I built with concrete walls but had to use wood on the roof areas.
/ Glulam Beam - Checking Problem #86
We also have a dry climate and wood just splits, no matter what one does. I do keep my stocks of wood that I am planning to use strapped at all times. It doesn't stop the checking, but it does slow the warping. With items like fences, I come back a year or later, and add fasteners where needed. Some boards warp too badly to keep because they were sawn poorly and warp as they hit final dryness. It is what it is.
It seems like you have a detailed engineering calculation there. That would be reassuring to me.
All the best,
Peter
/ Glulam Beam - Checking Problem #87
It strikes me that the portion of the wood under the check/split is still in tension unless it completely separates at the ends from the other parts of the beam. I assume given their computations that the manufacturer is assuming that that portion is no longer useful in case of complete separation. Personally I'd go with injecting a glue in the split and compressing from below just so that there's no visually obvious sign of the checking, but it looks like the calcs say it's fine otherwise. I don't think the screws are necessarily a good idea as others have mentioned in that they will compromise some of the wood fibers for dubious gain.
We have a 28' beam in our house; originally our house was built basically as a 2-story only with the top floor finished and a cavernous crawl space; when we bought the place, we realized that it would be a great daylight basement (actually there are small windows on the uphill side as well so we don't need lighting except at night).
In the big room where the beam is, it replaced a bunch of columns in the previous crawlspace; originally they said something like a 24" glue-lam (idk this was 1996) and I was like "um that's going to intrude quite a bit into our living space - like 16" or so - how about a steel I-beam? and they're like "???!!!" so instead we've got a 5" intrusion in that ceiling that's wrapped in sheetrock (required for fire actually).
Engineer also mentioned that the glue in the glulam does NOT transfer shear, per their calculations. The wood fibers transfer shear while glue adheres wood together but for calculation purposes, they do not use the glue to transfer shear. The beam never de-laminated but experienced checking in the wood fibers.
The engineer said that most glues are "expansive" and when injected, can actually cause further splits/checking to form elsewhere as the glue expands and pushes on other glulam members. He said the screws will provide the proper specs to bring the beam back into its original strength.
/ Glulam Beam - Checking Problem #90
Some glues are certainly expansive in that the wood swells a little, as it absorbs glue, but that's one of the reasons to compress after glueing to maintain dimensional specifications, as well as to improve the glue to wood fiber bond. I have glued wood both ways, both work. I think one of the challenges for modeling a glue repair of checking is the very nature of the irregular surface, and how that irregular section would alter the transmitted forces. Screws are much easier to model and predict.
To me the great thing about the check is that it is along the fibers, in a beam that you want fiber strength. So at a first approximation you have lost very little of what you / your engineer want/need for functional strength.
Again, it sounds like your engineer is looking after you well.
All the best,
Peter
/ Glulam Beam - Checking Problem #91
That sounds strange. If the wood/adhesive bond line doesn't provide shear resistance, you might as well stack the laminations dry, allowing them to slide across each other.
You keep repeating 'the beam didn't delaminate' but, while that may be technically correct, one of your pictures shows a feeler gage going in full depth very close to, if not on, the glue line for what appears to be a substantial portion of the length. And the allowable checking, shown in a later post, is exceeded so remediation is required.
Does the beam currently show any sag? Does the remediation procedure include jacking to remove some load while the screws are being installed?
I think what the engineer was saying is that when they do load calculations, the glue is not given a "value", only the wood itself is given a load calculation value. Of course the glue is key to bonding the beams but the glue itself is not given a load value when calculating for shear resistance. They calculate the loads/strength using the boards. This is probably done as an extra safety factor in designing the beam size. If the glue was given a shear transfer value then they could reduce the size of the beam but they error on the side of caution and oversize the beam.
When the feeler gauge goes in, it does not go in straight, it will turn up. In other words, the check is not a clean line but rather a jagged line with wood fibers that prevent the feeler gauge from going in straight. A de-lamination would result in a clean break in the board, right at the glue line. There would be no broken wood fibers and the feeler gauge would go in cleanly on a straight line. The checking is a jagged line that contains wood fibers throughout. If it was a de-laminiation (wood glue) failure, that would be a totally different issue and fix.
There is zero sag in the beam. No jacking is required when installed the screws per the engineer's calculations. The beam did not fail or break.
I am not an engineer but I can't see them cutting corners as their liability is extremely high. Engineer's will always error on the side of conservative caution to prevent any future issues. They don't want a roof failure and be held liable for providing a fix that was doomed to fail. The engineering repair was stamped and sealed by a state licensed engineer that is well-versed in glulam beam repairs.
/ Glulam Beam - Checking Problem #93
By not including glue shear, he is making the assumption that the glue lam can be considered as one solid piece of wood. That works as long as the glue doesn't shear, AND as long as no deep cracks form.
An analysis might not include glue, but it has to include deep cracks - even if he doesn't want to do so. Reason is that when a crack goes through the beam deep enough, then what you are now looking at are two stacked beams, not one solid beam.
You are probably concerned more with deflection than simple shear.
/ Glulam Beam - Checking Problem #94
Yes, the glue isnt accounted for because they are "assuming" the glue is at least equal to if not stronger than the wood. Therefore they are treating it as if it were one solid beam....without glue.
And yes, proper glue should pull wood fibers apart before the glue separates
That is one thing the engineer emphasized is that the glue did not fail as the checking is in the glue fibers.
Is the engineering fix a proper fix? Or do some people here think it's not?
/ Glulam Beam - Checking Problem #97
I think you'd have to engage another engineer to get a good answer to that.
It's good that you've got all this documented now in case there's failure going forward, but I'd bet that no failure will be compensated fully for the resultant stress (between now and the eventual failure) and then dealing with the results of the failure at the time it happens (if it does, of course; I'm not saying it will, just saying that I doubt you'll be well-compensated if it does).
Damn tough situation.
Makes me wonder if you could somehow get a piece of steel U-channel under that beam from one side to the other as backup.
/ Glulam Beam - Checking Problem #98
I have no idea if it is or not, but you have the advice of the manufacturer's engineer, written, and documented. If it were me, I would do as they suggest, and document that, for yourself and them.
Then I would forget about it. Between the original engineering reserves, and your repair, I doubt that your actual loads will ever present any problems.
All the best,
Peter
2023 Kubota L6060HST Compact Utility Tractor (A63118)
2023 Kubota...
2019 KENWORTH T880 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T880...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
John Deere 5525 (A60462)
John Deere 5525...
