rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,817
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Before you sign off on it, it may be worth keeping your options open. As I look at those photos again there seem to be separations beginning between other layers in addition to the large one. It may just be an artifact of the photograph - but you may want to take another look. If the beam was laminated too wet it is hard to see how that is going to improve with lag bolting.It appears that is what the engineer will require. Running long lag/timber bolts through the bottom to bring that bottom glulam back to where it was and prevent any future issues. It did NOT delaminate (which is a different problem all together) but the bottom board was initially glued into place and it checked so it will be mechanically connected with the lags/screws.
Maybe it is acceptable to their engineer. My own experience with glulams is limited to one project. If it were mine I'd probably accept an opinion from a licensed professional engineer's as long as it included guarantees into the future.
rScotty
